Results 1 to 20 of 20
Thread: hmmm pls help
    1989 vn berlina
    Aug 2008
    lismore, NSW
    Default hmmm pls help
    kk i just bought a 1989 bv berlina for a whopping 250.00 of a old mate who i used to live next door two
    now i went down to look at it the other day and he shows me receipts for a new radiator ( 1month ago) and a compression test ( 4 days ago) and says that it was losing a tiny amount of water / coolant but he wasnt sure where.
    i check the rocket cover cap and sure enuff milky white buildup, and theirs oil in the radiator and resovair , i also noticed a little bit of constant white smoke coming out,
    so im thinking a blown head gasket but would this not have shown up on his compression test which come back all clear???
    any ideas / help greatly appreciated
    also i asked and he hasnt noticed any performance loss with his driving around town
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    He didnt pour coolant in the rocker cover by any chance lol. Apparently head gasgets are extremely rare to go on a VN V6, maybe you have a rooted Intake manifold gasket instead?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Not necessarily. A head gasket can leak coolant but still be OK under a compression test. It may be gone at an oil gallery, not at the cylinder. The only way to be sure is to pull it apart and look. Oil in the water and water in the oil is usually a good indication but, it may be just the inlet manifold gasket too.
    Visit my Facebook page
    NORTI's Avatar
    May 2004
    Quote Originally Posted by Mack View Post
    Really? Thats the first thing that went when Ben bought his.... lol back when he trusted me to fix it
    1989 vn berlina
    Aug 2008
    lismore, NSW
    kk ill have a look at the inlet gasket tomoz i never thought of that
    thanks guys
    vn calais, vs clubsport #137
    Jun 2005
    check all ur bolts are tight and actually there, when i bought my car one was actually missing. :S go figure.
    1989 vn berlina
    Aug 2008
    lismore, NSW
    all bolts were there, and the gasket looked in decent condition i guess maybe this is the head gasket /sigh heading down to repco today to get a full gasket kit
    ty guys
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by taskmaster View Post
    ty guys
    As far as I know you have to take the intake manifold off anyway to change the head gasket, so you can inspect the intake mani gasket properly then.
    VN S1 V6
    Aug 2008
    no mate, you just pull both heads and manifold off as one.... lol, just kidding, yeah. may aswell just pull it all apart and see what you find. nothing to lose right? it was only $250 lol. i got my VN for $500, but its in fairly good nick lol.
    1989 vn berlina
    Aug 2008
    lismore, NSW
    woot got half way back from repco today and got pulled over by the nice boys in blue asking rather rudlly why oil was coming from my exhaust pipe.... i luaghed and went to look believing it would just be smoke but nope actual liquid oil coming from my exhaust
    one 60.00 tow truck ride home later and a nice yellow sticker i have another thing to find any idea on this one .. i still havnt even bothered to look at the car yet since it got home
    Black VN MANUAL
    Feb 2007
    Top of Vic
    lol not your luck mate, gotta laught at sh1t like this tho its only 250, the guy could have taken it in and got 4-500 from wreckers for it lol, just pull her apart and find out whats the go start with inlet manifold sound like head gasket but if u get a VRS gasket set and do it all thats the way to go. good luck
    ~ VN POWER ~ Click the scales
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Well, sounds like either a head or a intake mani gasket. Replace both. head gaskets and do the intake manifold one, unless you can clearly see its the intake mani you may be able to skip the heads...Time for opperation!
    1989 vn berlina
    Aug 2008
    lismore, NSW
    pulled her open this morning yeah it was th head gasket or rather what was left of one, got it flat tested this morning also and all good there so about to pull it all back together again now and doing a major service while im under the hood save me coming back to it anytime soonand then hopefully get this canary off tomorrow... ty all for your suggestions
    still wondering how it passed a compression test lmfao
  15. #15
    Black VN MANUAL
    Feb 2007
    Top of Vic
    good job mate, now take the heads in get em cleaned up and shaved up the compression while your there 40 thou would go good
  16. #16
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    And blow the bottom end....good idea.
  17. #17
    Black VN MANUAL
    Feb 2007
    Top of Vic
    depends on the Ks, if its healthy and driven properly it shouldnt do sh1t.
  18. #18
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    How hard is it to do the head gaskets on a V6?Im looking at a series 1 VN Calais on the weekend for $450(prob less) and im told it got hot and now has oil and water mixed.
  19. #19
    NORTI's Avatar
    May 2004
    I didnt find it that hard at all. A gregorys might be helpful if your not sure.
    (Also Im female if that helps )
  20. #20
    1989 vn berlina
    Aug 2008
    lismore, NSW
    in response to adam69 it can seem daunting at first but its not really that hard but if your car has a blown head gasket i highly suggest getting the head flat tested before just swapping out a gasket ( makes sure the heads not warped , cracked)
    a gregorys manual is also a good thing just to have around or if you got a holden dealership in your area that is willing to photocopy a couple of pages from the holden workshop manual thats even better
  1. Exhaust... Hmmm
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2010, 03:01 PM
  2. Rims ... hmmm?
    By Soud in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-04-2008, 01:01 PM
  3. hmmm...
    By Ghost in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-07-2005, 10:08 PM
  4. Hmmm
    By stretch in forum Jokes/Humour
    Last Post: 24-04-2004, 01:48 AM
