were can i find air flow senser on a seres1 eng
you dont have one. helps if you choose a better title too
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
Not talking about a Oxygen sensor are you?
the sensor u mean is located under the throttle body bend, behind the throttlebody, and b4 the intake manifold.... there is a throttle position switch,[ attached to the throttle butterfly] and also a airflow meter....
u will know the difference..
i found them when my vn was runnin really rich and was suckin heaps of air...[dam screw snapped off the air-flow sensor..]
no there is no sensor there. youre either talking about an idle air controller, or the MAP sensor
wot is that sensor way down the bottom at the front of the engine called again? have u checked that my car used to stall and i tipped a bit of water on it and it started good as new then finally got it fixed
If We All Drove An SS, Who Would Drive The Execs!
thats the crank angle sensor
