replaced fuel filter,cleaned injectors,replaced air filter,fuel system all good,service light comes on stays on ,it wont idle in morns properly when i start it just cuts out when ever it wants ,,i have checked diagnostics and when light engine light is on it wont show any codes but when light goes out it shows in the codes that there is no problems and it is starting to wear me down can somebody please help
sounds like a faulty ecu or memcal. If the engine light is on without errors it's a memcal or ecu problem and the car will be in limp home mode, generally will idle faster and be down alot of power, it's possible one of the pins on the memcals eprom has broken it's solder, I've seen one before like that
thanks foam will replace memcal and ecu will let you know how it goes
