Results 1 to 12 of 12
Thread: V6 timing chain is 500,000km old. Hard to replace DIY?
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Question V6 timing chain is 500,000km old. Hard to replace DIY?
    Title pretty much says it all
    What benefits should I see in replacing the timing chain?
    What are the pros and cons of a double row chain?
    Is it difficult to do at home?
    Sam
    WTB: mulberry VN interior parts
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by savage1987 View Post
    Sam
    Savage i wrote a little aritcle last week or so when someone asked the same question. IMO double are pointless they wont do anything that a good qaulity single can't handle on a v6 plus you'd have to remove your balance shaft as they foul on the gear. Stick wiht a good quality one like rollmaster or crow. As for doing it at home its not really hard may take a while the only problem is the sump gasket is bolted to the bottom of timing so some silicone will be needed to stop it leaking. It would be better to take sump off but that requires removing engine or dropping k-frame.
    Anyways here's a the previous thread
    how to change timing chain
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Thanks mate, will get onto it. Definitely not taking the sump off
    Good write-up by the way
    Sam
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    oh crap here we go, am i getting invited around for more beers soon am i sam?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    timing chain is fairly simple to do. in regards to the sump gasket, i actually cut mine off flush at the block, so you end up with a piece of "V" shaped gasket. i put sealant where i cut the gasket, then i fitted timing cover and then pushed the "V" section of gasket between the timing cover and sump before tightening everything.
    double row timing chain is overkill, i only fitted one because the ballance shaft was making noises and it was coming out, funilly enough, the double row chain was cheaper then the single row one.
    Body by Holden, Soul by Brock
    the Legend will live forever
    89 VN Exec, 94 VR SS
    Dec 2007
    My timing chain would make noises,horrid noises so I asked my mechanic if there was a point to changing it, he charged me just for the part and all it did was make this wooshing sound at low revs go away. Unless its rooted I think all you need to do is tighten it
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    timming chains can suffer from stretching etc....and on a 500 000 k engine it cant hurt can it lol. i replaced mine on me vn that had 324 000 and it mad heaps of difference and it wasnt bad only thing was the tensioner was rooted. also there is no adjustments on the chain. the tensioner keeps it tensioned.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by Zuicider View Post
    lol nope, car and motor made of rubbish.. it doesn't deserve a timing chain. It can keep rattling around with the tensioner in the sump until it dies in spectacular fashion.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    lmao you will problem be waiting another 500 000 kilometers then
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    1993 Series II VP Calais
    Sep 2006
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    lmao my wheels are mine
    and my brakes won't fit your car. VN s1 V6 tiny ones. Unlucky for you
  1. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  2. timing chain
    By timboco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2006, 06:09 PM
  3. timing chain
    By howareyou in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2005, 05:49 PM
  4. vn timing chain
    By kacriss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2005, 07:02 PM
  5. VN Timing Chain
    By Michal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2004, 08:39 AM
