Results 1 to 7 of 7
Thread: VN V6 losing power after 3000rpm
    VN_Pretz is offline TNTGMH
    VN S-Pac 5spd V6
    Aug 2006
    Geelong, Victoria
    Default VN V6 losing power after 3000rpm
    hi guys, i drive a VN V6 5spd
    take off in 1st, a little weaker than usual then as i reach 3000-3500rpm it goes really powerless, then shift to 2nd and same deal, best way to describe it is, if you have gas, when your running low on gas and you put the foot down, it does nothin, i'm experiencing that but my car isn't on gas
    the only thing i can add is that my fuel pump sounds really tired, could this be the problem?
    any ideas would help, thanks guys
    pretz-
    Jul 2008
    Yes fuel pump, Or your crank angle sensor is on its way out, A Old m8 i dont talk to any more had the same prob on a VN, was his CAS. Shortly after he also replaced the coil pack, My money is on one of those 3 things, start with the cheapest.
    rawsonn is offline wants to know more
    VN Berlina
    Aug 2008
    Goonellabah, NSW
    id say cas also
    i love freedom of speach because [ details deleted by moderator]
    VN S-Pac 5spd V6
    Aug 2006
    Geelong, Victoria
    awesome, thanks guys
    i changed my oxygen sensor as i tripped the computer and got code 13, but that didnt help any, although i'm getting code 12 now (system clear)
    will start with coil pack as i already have some :-D
    cheers
    VP Executive R-spec
    Jan 2005
    If it's not breaking down and missing at all but simply running out of power. Then, fuel system for sure and since you say the fuel pump sounds wonky...... well you allready know what it is
    VN S-Pac 5spd V6
    Aug 2006
    Geelong, Victoria
    skyper is offline SKYPER
    SV6
    Aug 2008
    LISMORE NSW
    my car did the same 4 years ,i thought that was how vn's went untill the coil packed it in, and now it reves clean, if the coil has gue coming out of it ,it is dead
  1. my V6 is losing power.Help !!
    By custom vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2007, 11:01 AM
  2. Losing Power
    By AdamAnt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2007, 12:58 PM
  3. VL missfire losing power
    By STYALR in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-06-2006, 06:56 PM
  4. Losing Power
    By My Car Pwns in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-12-2005, 11:33 AM
  5. V6 Power surge @ 3000RPM....Curious
    By SPack in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-10-2005, 11:36 AM
