Results 1 to 11 of 11
Thread: Cruise Control
    5 Speed VN '88
    Feb 2007
    Default Cruise Control
    Howdy i know there is plenty of threads about cruise control but i cant find anything about wiring it up without using the loom. I have the switches on my dash installed, i have brake switches and the actual cruise module with the cable.
    What i want to know is, are there wires behind the dash or in the engine bay that i can use to connect to the module or do i have to run all new wires?? Becuase the switches on the dash plug straight into where the old switches are. i know of the plug that is in the engine bay in some models but i dont have it in mine. I have a series 1 vn exec by the way.
    The reason i ask is because i cant seem to find a loom with the cruise control plug in it already.
    Thanks for any help.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by vn88 View Post
    I may have access to a CC loom. I'll call them tomorrow.
    and 3 Dangerous non ABS VN's
    5 Speed VN '88
    Feb 2007
    that would be great thanks mate. ill check here tomorrow afternoon
    thanks
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    88GreenVN's Avatar
    Jun 2006
    Ok Yes he has one - I'll grab it off in Friday arvo. He will look up the price of it for me - but wont be all that much. It is a new factory Holden loom used to retro fit cruise at dealerships. I can solder pins on the green & white wire so you can plug straight into the back of the main dash plugs. Then you have the earth (goes near the battery) & brake switch wires and the 4 wires that go to the switch block. Also I can put 4 pins on tham also if you like.
    Then it's just a small hole/grommet into the fire wall for the loom to go through and you are done.
    5 Speed VN '88
    Feb 2007
    thanks mate. Ive sent you an email. If you could solder the pins on that would be excellent as well, i'm not the best at soldering.
    thanks again,
    Matt.
    88GreenVN's Avatar
    Jun 2006
    thanks again,
    Matt.
    Did not get the email - but I did get the CC loom
    88GreenVN's Avatar
    Jun 2006
    Some how I only had 3 pins (4 needed) for the switch block plug. Just dunno - the 4th pin is Gone. The green & White have pins for the 2 dash connectors.
    Problem is I wont be back to the wreckers until next Friday. (to get a plug off a loom to scab a pin out of.
    5 Speed VN '88
    Feb 2007
    Thats alright I'm in no hurry mate. Send me an e-mail when you've finished it
    Thanks,
    Matt.
    88GreenVN's Avatar
    Jun 2006
    Thanks,
    Matt.
    99.9% done. Never mind. I'm taking some VN Calais rims & tyres down to the wreckers next Friday - I'll get it done early so I can make the arvo post for you.
    88GreenVN's Avatar
    Jun 2006
    All done now - I'll put the Cruise Control loom in the post for you (VN88) Monday morning.
    Bugga not having the extra pin - lost 1 week - never mind.
  1. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  2. Cruise Control
    By Summer-Sickness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2007, 08:01 PM
  3. Cruise Control
    By ROBS_STATES_MAN in forum General
    Last Post: 02-09-2006, 11:45 AM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  5. cruise control no control
    By foxinjox in forum Electrical Wiring / Questions
    Last Post: 16-11-2005, 01:32 PM
