Results 1 to 24 of 24
Thread: Accident No 2 For the 89 Green Sedan
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default Accident No 2 For the 89 Green Sedan
    The 89 Green sedan did a 360 in the wet while exiting Colinnaides the other day. The Daughter said the car did a big fish tail and then went up the gutter backwards putting a big dent in the rim. The tyre survived.
    Looks to be no major damage but for her pride.
    We sat down and talked it over on how she came to spinning a car out. (usually the 17 year old cant be told - anything) but she sat and talk - I did not get sworn at (at last a normal conversation)
    As it turns out she nailed it out of the corner and even with a miss in the engine she managed to get the car to go around 1 & 1/2 times and not do any real harm. Very aggressive for a P plate driver of 3 months.
    So now it has hit home that you can come unstuck real easy.
    I put 2 215's TZ100 Firestones on the rear to replace the 205 Turenza's and hopefully gain a little more grip for her.
    Looks like she will need it.
    and 3 Dangerous non ABS VN's
    Astranomical's Avatar
    Astranomical is offline Ecotec just kicked in yo
    Hammerhead Eagle i-Thrust
    Apr 2004
    Dee Why, NSW
    Good to hear that both car and daughter survived unscathed! Just look on the bright side - at least it wasn't the Wagon.
    Quote Originally Posted by som
    i saw a camira a while ago that wasn't blowing smoke.it was on the back of a tow truck.
    Jun 2005
    good way for her to learn. glad noone was hurt and car isnt damaged
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VT V8 Calais
    Mar 2007
    It is good for a young driver to get a scare like this. It gets ride of the "I am invincible" attitude and makes them start to listen.
    Exactly the same thing happened to me when I was on my p's
    When my kids get older and start driving I really want to take them to a skid pan and show them how easy it is to loose control of the car, I think they would learn a lot.
    50LTRv8
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by goVZ View Post
    Hmmm funny you should say that - as it turns out the eldest daughter has also spun the wagon out 1 month into getting her P's too (found this out last night). Had the car sideways across 2 lanes blocking traffic in both directions for a while. She did not say anything as she thought I'd take the car off her.
    Slowed her down thankfully.
    VP Executive R-spec
    Jan 2005
    Don't make your daughter sound too cool , all the youngins on here will be after her.
    My Mum managed to loop her 1977 Celica around in the rain and gently grind it's belly across the median concrete/tiles in the rain one time so I except it's easy enough to do in a VN if you have a heavy foot that doesn't back off quickly .
    (Greenfoam and Mortons's budget racing team recommend Highway max performance remoulds for all your wet weather traction needs)
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by stocky View Post
    Yes I think we got through - At long last.
    And as it's her first car you expect it to gain a few nic's and dents along the way. Too bad the mags were almost new when I got the car for her with no gutter rash at all. Now 2 rims are now - well 1 has some rash & 1 a big dent in the edge of the rim about 20mm long and 8mm deep. Should be OK - it has not bent the rim - they tested it when changing the tyres.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by greenfoam View Post
    LoL 1977?? RA28?? They go nuts with the newer 4age i think they are... *dont remember my sillycar motors that well*
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Jul 2008
    Ive done this once of twice, happens to everyone i think. Havent crashed from it though, just looped it and made it look like thats what i wanted to do, i was driveing a FWD but.
    VP Executive R-spec
    Jan 2005
    I've never looped my VP around but I have landed all crossed up in the wrong lane quite a few times, allways my fault in a moment of stupidity when no one was around
    88GreenVN's Avatar
    Jun 2006
    I thought the engine may have been on it's last legs with the miss it had, but no - poweer to burn. The injector cleaner has helped lots - still a minor miss but still enough power to loop the car and get it up a gutter - and this was on a blind exit "T" junction were you almost have to stop to see if anyoe is comming from the right. She gave it plenty by the look of it and was around before she could blink. When I got the car the Brigestones on the back were new but dont offer enough grip in the wet with the tune that it has.
    88GreenVN's Avatar
    Jun 2006
    She has a French boyfreind (3 years) that calls her every night.
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    did the front or rear wheel(s) hit the gutter? if so you might want to check the alignment of the diff.
    VP Executive R-spec
    Jan 2005
    Lucky it's you that has to listen to his accent and not me , it grates hard on me even after being out of England 150 years :0
  15. #15
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    Sad to hear about the spin - but very good to hear that all is mostly ok!
    just double check the panhard rod mounts and stuff - apparently they have a nasty habit of tearing off!
    at least you didn't get the "Swerved to miss a dog" excuse! - those stupid dogs just seem to run out of nowhere - in front of inexperienced drivers, in the wet, just after a corner all the time!...
    I've looped a car more times than I can count/remember - but not in 'public/traffic' as such - after a while you get into the habit of hooking reverse, mashing the gas, and J turning out of it.
    YouTube - VP Spin Recovery
    ... or keep spinning until you get the right direction :
    YouTube - More VP spinning
    LOL
  16. #16
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by vnv8driver View Post
    They had a good look over the car at Expressway Tyres. Car still drives straight so looks to have come out of it OK.
    At the time I wanted her to think it could be many hundreds of dollars damage if anything was bent.
    And the Commodores dont like going up gutters at all - so could have been a great deal worse had she hit other cars or smashed up the front end. Going up the gutter backwards probably saved the front end.
  17. #17
    88GreenVN's Avatar
    Jun 2006
    Ha Ha - he speaks very good "UndGlush" and spends little time in France.
  18. #18
    304 Calais
    Aug 2007
    Up your mum
    good to hear man, you would of noticed if the diff was smacked out of place, i saw this 1 dude driving with the tyre scraping on the quarter arch!!!! ouch.
  19. #19
    88GreenVN's Avatar
    Jun 2006
    The car looks to have hit the gutter almost square on with the drivers side rear wheel. How the gutter rash got on the front I dont know yet. The panhard rod mount braket is very sus from sideways impacts so by hitting the way it did - looks like no damage at all.
  20. #20
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by 50LTRv8 View Post
    Spot on, I was the same, Stopped me in my tracks fast.
    Cops pulled me up days after my P's, They were hard on me, Embarrassed me, Shammed me, IT was the best thing ever.
    Also glad to hear no one was hurt and car is fine..
    I went for 225's on 15" on the VP, And that has better grip then my Berlina, In all conditions.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  21. #21
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Mmmm Highway Maxx, the value per dollar you can get! Those tyres are unbreakable!
    Quote Originally Posted by 88GreenVN View Post
    Hahaha oh wow, it's ALWAYS possible to get the end out on one of those things, hey Especially for a novice driver who thinks more power = go faster, without thinking about the wheelspin inbetween
    The 1972 HQ Kingswood
  22. #22
    Kikki's Avatar
    Kikki is offline WA Cruise Moderator
    08 VE SSV Sportswagon & 98 VT Berlina Wagon
    Aug 2007
    Eaton, WA
    Lucky she is ok! Glad she got a fright lol hopefully wont be trying that again.
    I did a similar thing (a little embarrassed to admit it *hides*) but about 3 weeks ago I was on my own, of a night, wet road, off to get fuel, got to the corner of my street to turn right, then the "Evil Christie" says "Go on give it ****" new car, kind of proud, stupid me did and next thing you know I'm facing the opposite direction to what I should have been, and missed the gutter by at least an inch NEVER will I do that again!
    The difference between the VX Sedan and the VZ wagon is HUGE and I learnt that the hard way lol! I should of just asked Craig....
  23. #23
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    i assume the road was wet
    i find the roads down there really dangerous, the round about where you can cross over the train track bridge was really bad until they resurfaced it
    i have found my self sliding when i wasnt trying, my old woman was in the car too at the time and she crapped her self, corrected it just before i got close to the lamp post on the side.
    also the exit near the train staition is really bad, seen my cousin loop out but he was trying to be a hero
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
  24. #24
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    i spun my old lexcen in the rain going round a roundabout, put the fear of god into me.
    The Black Beauty
  1. VY Hothouse Green sedan.
    By witto123 in forum VY - VZ - WK - WL - V2
    Last Post: 09-05-2009, 09:29 AM
  2. Will VN Sedan Rear Shockers / FE2 Springs fit into a VH Sedan?
    By VHSLX3300 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-01-2007, 12:28 AM
  3. Accident
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2006, 01:51 PM
  4. I just got into an accident...
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2005, 06:55 PM
  5. My Accident
    By Infus10n in forum General
    Last Post: 04-08-2005, 02:28 AM
