Results 1 to 6 of 6
Thread: Bored out throttle bodies
    VT V6 twin Turbo
    Feb 2005
    Newcastle region
    Default Bored out throttle bodies
    hi just enquiring if it is worth the money to get a 70mm throttle body how much more petrol would it use versus hp thanks
    VX SS
    Oct 2004
    Mandurah W.A
    better throttle response thats about it. 70mm is too big but because the whole intake isnt 70mm i think its max 69mm
    QIK62C Guest
    VP Executive R-spec
    Jan 2005
    I've pulled my throttle body apart a few times lately for a bit of porting, but I haven't bored it out, just reshaped it a bit and cut back the shaft. Still it would be fairly easy to bore one out to a larger size any machine shop would do it for you but then you need to make a new and perfectly round butterfly, that might not be so easy. The stock one should flow around 500cfm anyway and that's allready more than the engine can breath going flat out
    VP Executive R-spec
    Jan 2005
    Oh yeah, here's my thottle body adpater and throttle body, I've been paranoid ever since I looked at this picture did I forget to clean out the metal shavings from the last grind I did? which was the brass screws hanging out aftet I cut back the shaft, I know I cleaned the adapter after taking the pictures but well... Anyway too late now if I did forget, because I've been driving it for a week, lets hope brass is really as soft as it seems : ). All I've done with the TB is cut off the edges that are at the front and back and blend the front edge to a smooth curve, gave the butterfly half an edge and cut back the shaft, did a dodgy job of that because I left it all bolted together, held open the butterfly with one hand and held the die grinder in the other at 20,000 rpm heart in your mouth stuff that is and yep I did end up taking a chunk off my thumbs knuckle (nothing that wont grow back) but the TB was ok! : ). So the two leasons for the day are, wear gloves and make double triple sure things are clean before going back on the car
    VP Executive R-spec
    Jan 2005
    I missed out on buying a really cheap TO4B turbo today on ebay by 2 dollars and a couple of seconds, blah! oh well maybe next time
  1. throttle bodies
    By dmitch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-09-2006, 11:16 PM
  2. Throttle bodies
    By big_c_43 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-07-2006, 07:56 PM
  3. S/C or 402 or 8 Throttle Bodies?
    By slowr8 in forum Projects
    Last Post: 29-05-2006, 11:06 PM
  4. throttle bodies
    By bangers in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-02-2006, 08:05 PM
  5. throttle bodies
    By doggie458 in forum LSx Development and Modification
    Last Post: 14-10-2005, 09:29 AM
