my vn had the same problem and i ended up makeing up a braket with some thin metal.....hard to explain but see the pics...
lol the one one the drivers side on my vp was zip tie and a broken in half biro pen worked a treat![]()
Originally Posted by Smidy
I thought the blove box liner was removable in those?Shouldnt need to replace the whole dash.
The 1972 HQ Kingswood
It is on the later models, VR and VS but not on VN/VP.
There used to be a part available through Holden spare parts that reinforces/replaces the broken section. It was (is) a piece of steel angle which is screwed up into the downward sloping face of the dash with the other side (at 90 degrees) hard up against the piece of the dash the hinge pin goes into (between the glovebox and the piece the hinge pin goes into). The hinge pin then runs in a hole in the piece of steel.
I don't know if you can still buy that but I made one out of a piece of 25mm X 16mm X 1.6mm ??? (Not sure if that's exact mm) Aluminium angle bought from a hardware store.
