Results 1 to 5 of 5
Thread: steering column help!
    VN commodore 3.8L
    Aug 2008
    Warilla, NSW
    Angry steering column help!
    hey guys,
    me and my mate tried taking my stock steering wheel off the other day, and it wouldnt go no where haha,
    we tried one pulling on the steering wheel and the other hitting on the nut with a hammer,
    and stupidly enough ive stuffed the thread on it so the bolt wont go back on ,
    whats the easiest way to get the thing off?
    and im pretty sure im going to need a whole new steering column casue i might have wrecked the inside bearing and ive wrecked the thread anyway ,
    is it easy to put the steering column in by myself?
    or just get someone that knows what there doing to do it for me?
    thanks guys for all your help and hope you can help me with this,
    much appreciated!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I ended up half sliding the shaft out so when I tried to put the steering wheel back on the horn would not work? Had me puzzled for a few days. The wheel just would not come off. That was untill I used a plastic mallett, my knees under the wheel, left hand pulling back on the wheel and bashed the pooh out of it with the mallett.
    If the bearing is stuffed it probably will be best to replace it while the colum is out of the car.
    The centre shaft is a snug fit and can slide apart when trying to get the wheel off. It taps back into place easy as.
    and 3 Dangerous non ABS VN's
    MasterOfReality's Avatar
    MasterOfReality is offline Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    VN commodore 3.8L
    Aug 2008
    Warilla, NSW
    yeah thats true,
    my mate is wrecking VN and he said he'll sell me a steering wheel with a boss kit and the whole steering column for $50,
    so im just going to take the whole thing out and put the new one in.
    hopefully it works out!
    vr commodore
    Aug 2008
    hi matey ive changed a few steering wheels my vk i undid the nut pulled on the steering wheel and the whole steering shaft came off so i had to replace the whole thing ops my vr i had more luck with i just undid the nut so it was at the top of the thread then pulled to the steering wheel while hitting the nut with a rubber mallet hard but not to hard. a tip for installing the new steering wheel fit it but dont push it all the way home dont put the nut on go for a drive (take it easy) so you can ajust the wheel so it is straight when it is push all the way home replace the nut too easy because ya dont want to take them off again if ya dont have too. trust me it is a bitch.
LinkBacks (?)
  1. getting steering column cover off
    By reformed99 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-07-2008, 06:40 PM
  2. Steering column rubbing
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-03-2008, 11:18 PM
  3. Steering column (with a twist)
    By stockhorse in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2007, 10:29 PM
  4. vr steering column
    By 5Lvrss in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-03-2006, 06:47 PM
  5. steering column key lock Help
    By sherr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2006, 08:11 PM
