Results 1 to 12 of 12
Thread: vn / vp v6 fuel pump rating ?
    Feb 2004
    Default vn / vp v6 fuel pump rating ?
    hi, anybody know what a stock vn/vp v6 fuel pump flows ?
    thanks.
    mark k
    spacattack's Avatar
    spacattack is offline THE ENFORCER!!!
    Custom VN
    Mar 2005
    brissy
    lol nahh piss the stockos off get a merc 6cyl ( or 8 cyl depending on how big ya motor is) bet flowage and pump from a merc 99 on wards they fit suprisingly got one on mine
    jules's Avatar
    jules is offline we like the bun
    pimpin
    Dec 2003
    the computer will pump a stoichiometric 14:1 air-fuel ratio. unless you have devised a method of drawing significantly more air into the engine, trying to flow more fuel is a waste of time!
    Feb 2004
    hi, as per my original question, all i wanted to know what the original vn pump flows , so that when i find some used ones i dont get one that flows less than the standard.
    jules's Avatar
    pimpin
    Dec 2003
    no idea
    why don't you just make sure to buy the right type of pump and stop worrying about flow rates?
    Feb 2004
    why buy when i might be able to get ,a used one or dont want to get a new one ?
    what about if i had several efi pumps that are suitable? flow more than a vn one ? why then go out an d buy one ?
    jules's Avatar
    pimpin
    Dec 2003
    just go off the power then. the VN made about 130 flywheel kW. if the pump you are going to use is off a KE laser making 50 kW then it won't flow enough.
    that would work as a rough guide.
    Feb 2004
    Quote Originally Posted by jules
    whats that got to do with the fuel pump ...???
    dont u know that u increse pressure you can get more power ????
    pathfinderus maximus Guest
    ah theres a little thing called a fuel pressure regulator
    to an extent, doesnt matter what pump you have, the regulator has the final say
    i have a hi pressure pump for vl feeding my series2 vn v6.
    just get a pump from a wrecker and bobs your uncle.
    actually i have one, which state you in?
    Feb 2004
    ah theres a little thing called an adjustable fuel pressure regulator......
    s0sage's Avatar
    s0sage is offline Posting aimlessly ..
    MX6 - Turbo .... so flame me
    Mar 2005
    now now kiddies lol
    your both right
    you CAN fit an adjustable fuel regulator... BUT you still are left with the problem of needing to get more air down the motors throat...
    OTHERWISE you should attach a bucket to the end of your exhaust to catch the unburnt fuel pouring out so you can recycle and save some money!! lol
    you need wider throttlebody or twin setup OR drill some holes in your manifold or something see how that works
    vh sle 5lt & vn berlina 5.7lt
    Apr 2005
    mandurah w.a
    if you check this the actual stoichiometric ratio of any internal combustion 4stroke petrol engine is 14.7:1
  1. Fuel Pump
    By vl1234 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-03-2007, 05:36 PM
  2. Fuel Pump
    By knight97 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-03-2007, 02:34 AM
  3. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  4. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
  5. vk carbi - fuel rating and throat size
    By NAY in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-06-2004, 12:55 AM
