| VN - VP Holden Commodore (1988 - 1993) Talk about anything relating to the VN - VP Holden Commodore. |
20-08-2008, 05:27 PM
Ride: 1993 VP Calais
CAI Installation
Hello,
I purchased a Holden CAI plus a K&N Filter, although I believe I'm missing a part.
Original Air Filter:
CAI + K&N Filter Setup:
Correct me if I'm wrong, but obviously there is a part that sits on top of the Filter, and connects into my intake pipe?
Does anyone know the name of this part?
Cheers,
Chris
20-08-2008, 05:34 PM
Ride: vl executive
you need the orignal airbox for it to work not the setup you have nowu have to buy the top part yourself
20-08-2008, 05:38 PM
Ride: Vp series 2
ok you had a pod ilter not the standard air box.
The air box is a 2 piece thing and one part bolts down and the filter sits inside then the top goes on and te pipe connects to it.
so you need the complete airbox and flexible joint to use the cai.
You also need to flatten the ends of the cai to about the bolt holes so it fits under your bonnet. A old iron can flatten this.
Banned
Ride: 304 Calais
Yep thats all that is in the vs s/c v6 kit. the original airbox can be bought from the wreckers cheap as chips, then buy a high flow panel filter.
20-08-2008, 05:42 PM
Ride: VP Executive R-spec
He's got the filter:P all he needs is a airbox lid and the small section of rubber hose and a couple of clamps
__________________
VP executive-R 0-60mph 5.36 11/10/07, PB ET 9.101 1/8th mile at Southcoast raceway 30-11-2007
VN Lexcen GL 0-60mph 6.95. 1/4 mile 15.37 @ 91 mph: calculated rwkw 114
VH SL/E 202 Auto 0-60mph 13.5
Aiming for 4.5 and to defeat stocky in the 4.9 second challenge, NA for the win
My VP, going fast on the cheap
20-08-2008, 05:45 PM
Thank you very much fellas!
20-08-2008, 06:01 PM
Ride: vn executive s2 v6
get the vs v8 lid as it flows heaps better than the earlier versions
20-08-2008, 06:10 PM
Quote:
The CAI I have is for a V6, will it fit?
20-08-2008, 06:37 PM
Fear my Vee-Peeness
Ride: SV6 VP
should fit, i was a derp and bought a VS SS CAI, not the VS supercharged, my snorkel still fit and still joins to the box. i think it's only the vn group a (and maybe hsv) airboxes that are different.
20-08-2008, 06:46 PM
I Am Not Your Friend
Ride: VP Calais Series 2
did you but from ebay or holden?
__________________
Check Out My VP Calais
Quote:
My name is Braff Zeckland. I was an international racecar driver. One day, a baby carriage rolled out onto the tracks, so I swerved into the retaining wall to avoid it. The car burst into flames, but the baby miraculously survived. I was that baby.
20-08-2008, 06:47 PM
Alright, also, there is a hole at the bottom of the air box, I read on another thread this was used to put in another pipe which goes to the bottom of the car?
Here's a picture:
What's the deal with that?
20-08-2008, 06:48 PM
Quote:
I purchased it from eBay Troy.
20-08-2008, 08:04 PM
was that the cai + kn filter for 150 bucks ?
__________________
20-08-2008, 08:28 PM
Fear my Vee-Peeness
Ride: SV6 VP
Quote:
Here's a picture:
basically you've got most of the setup you'll need, you just need the box top and the pipe-joiner.
originally the cars came with a box bottom like what you've got in that pic^^ but a smaller opening, because the snorkel wasn't stock. some folks widen the hole and put the snorkel in it (it sucks air from over the radiator)
as well/instead of this snorkel, some people run a pipe out the hole down to the bumper, but i think people have had worries with getting water sucked up too.
there's also folks who do the standard snorkel, but bore a hole in the bottom of the box and also in the metal of the guard under where it sits and pipe through there, don't do this tho, as it's defectable.
