Results 1 to 6 of 6
Thread: code 13 oxygen sensor
    8vl
    8vl is offline
    vl executive
    May 2005
    brisbane
    Default code 13 oxygen sensor
    heya gus and gals i am sorta new to this but my vp s2 has been running like a dog lately and i checked the fault code's and came up with code 13 ...
    would code 13 cause the car to idle fine but as soon as u try to drive it it run's like it's only on 3cylinder's i have checked everything i can ... and still lost in the dilemma ....
    misses and carry's on like a old b***H
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The O2 sensor reports to the ECU the gases on the way out and makes adjustments on that. If the car is carring on like a pork chop, I'd start by testing the coils/DFI unit, replace the O2 sensor & check the TPS.
    Also your leads can brake down under load - like it will drive fine on the flat - but hit a small hill and the car starts to miss when you put your foot down. Change leads.
    and 3 Dangerous non ABS VN's
    8vl
    8vl is offline
    vl executive
    May 2005
    brisbane
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    Look at the black box that your leads connects to, now the 'squashed' piece thats bolted underneath the black box is the dfi unit, its apart of the electrical system in other words.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by 8vl View Post
    i really hate to sound stupid here DFI unti ? location what does it do
    Basicly it hands out the zap to the spark plugs.
    If this stops working the car is kuput. Located as stated ^^^ above.
    8vl
    8vl is offline
    vl executive
    May 2005
    brisbane
    having alook at that now thanks for the help i let u know if it fixes the problem
  1. fault code 13: oxygen sensor?
    By sparra_gump in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2012, 07:08 PM
  2. No oxygen sensor signal code
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2008, 07:08 PM
  3. oxygen sensor on VN..
    By dylanfh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-06-2008, 09:18 PM
  4. Oxygen (O2) Sensor Swap [ Code 13 | 44 ]
    By Butso in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2006, 06:12 PM
  5. Oxygen Sensor
    By The1985divo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2005, 09:48 AM
