Ok im buying a vn on the weekend and just want to service it myself i just want to clarify what it is a need to do and how much itll all probably cost
1. New oil filter
2. New oil (i want good stuff)
3. Maybe a new air filter
4. New petrol filter
anything else i need and how much do u rekon itll cost
I've driven fast cars I've done stupid shit in them each time i seem to come out on top i love you guardian angel
vp ss 3 months to go
grab a can of throttle body cleaner/subaru upper cylinder cleaner and spray the intake (inside of throttle body), theres also a little hole inside, this leads to a sensor and usually gets blocked with carbon, start the car with the pedal flat to the floor as it will be flodded, then at a steady idle spray some cleaner into the motor. only use short bursts as it can damage the motor (petrol based cleaners). The subaru cleaner is the best type and contains mainly the cleaner, but has a little bit of lpg as the propellant. spark plugs and leads are a good idea as well if there a bit old looking. other than that, check out the suspension components, i bet there will be a bush or strut that needs replacing. other than that a good clean and it should run fine.
also before dumping the old oil, put some engine oil flush in the motor and run it for 10 minutes. You can get unlucky sometimes with a blocked pickup but 99% of the time it works a treat.
it really depends on what kinda quality we're talking about. you can spend $5 on oil or $70, air filters you can go stock paper, or reusable (k&n etc)
you should get out of it for about 150 buying pretty decent parts.
also, you might wanna do plugs too, depending on how old they are.
i know the guy at the local auto one so hes discounting it a bit for me so yeh i wanna get decent **** that will keep the car happy![]()
the thickness for an average km vn should be 20-50. If you got the cash get a high flow filter for 100-120, and add a cold air induction setup to deliver cold air to the motor. If your interested in a bit more push a new tune will do it wonders.
oh once the service is done ima do the ss induction and exhaust (extractors later) just to keep the old girl happy
mobil/repco branded semi synthetic oil goes for 18-30 dollars. a good oil flush and new oil/filter will keep it quiet & protected. if it has a bit of a tick before or after the flush at idle, add a bottle of nulon lifter free tuneup.
new 2.5 exhaust off ebay, 180 bucks
performance filter & cai, 140-200
chip, 45
corvette servo, 40
service with good quality parts- 200
you seem to know what ur tlkn about cheersso what just park my car over the drain on the side of the road to get rid of the oil or what?
KIDDING
weve all seen the sign that says holden p!sses on ford ima make a sticker that said joshua sh@t on a ford
i wouldn't bother with an ss inductions cai, a vs s/c should do just as well.
how much does that end up costing got any kits on ebay to show me whats what?
on the serious side where do i dump my oil
buy a plastic oil drip pan from supercheap
ok and i know this will seem like a stupid question but wat is a vs s/c
supercharged vs.
VN VP VR VS V6 Commodore Cold Air Intake & K N Filter - eBay Other Performance Parts, Performance Parts, Car Parts, Accessories, Cars, Bikes, Boats. (end time 24-Aug-08 21:03:09 AEST)
here is what everyone talks about mate.
hope that helps.
if the coolant aint too good. change it.
vs commodore supercharger
so if i get that cai then the exhaust set up then get in touch with green foam for a new tuned chip aye
Get an oil pan from super cheap, about 8 bux, drain it into that.... Then once done poor it into your oil container, or find a bucket with a tight lid. Take it down to your local tip/ waste station and they will have a thing you can poor it down. I have 20 litre drums I use, when they are full I just take them down and empty them. Or you can be like my mate and just throw it over the garden lol.
yep, the cai pictured in that ebay is a good one and comes with a reusable k&n panel, which flow higher too.
you'll need to widen the hole into the bottom of the airbox to fit the end of the pipe into it, or you can buy a new airbox bottom with the bigger hole in it, which it looks like this guy sells too. have a crack diy and if you **** it up get one from holden.
