Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: scrubing on inside rear wheel well please help
    smithy46's Avatar
    smithy46 is offline 5lt vp calais
    5lt VP Calais
    Aug 2008
    haha Radalaide SA
    Post scrubing on inside rear wheel well please help
    My vp calais is lowered and iv got a set of 17 by 8 inch vy ss rims on it and there's alot of scrubing on the inside wheel well so im barely getting any mileage out of the tires not to mention the horrible noise it makes when it scrubs. I dont have a camber kit would that help? any idea's appreciated.
    thanks.
    VE II SV6 Sportwagon
    Sep 2005
    gdai mate, ive got a vp calais aswell on 18"s, and my inside tubs are scrubbed out tha ****ter!
    its bcause the vp calais is a different offset to all other model commodores, so tha stock rims have no probs cause there made for that offset, but tha vy ss rims are obviously made for tha vy offset.
    Couple of things u can do, u can eitha buy wheel spacers (round 6mm or bigger) and chuck those one, though u then need longer wheel studs, to give enough thread to screw onto, or u can buy vr/vs hubs and put those on as there tha normal offset
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    smithy46's Avatar
    5lt VP Calais
    Aug 2008
    haha Radalaide SA
    cheers guys iv got spacers atm and no difference so ill try vr/vs hubs next see how that go's.
    still open for suggestions.
    Thanks.
    304 Calais
    Aug 2007
    Up your mum
    had another read, and i think i got your post messed up.. Do you have stiffer springs or are they cut stock springs??
    Vp series 2
    Jun 2008
    is it one side that scrubs?
    when you lower it the camber has to be adjusted so the wheels sit square. If you have not done this then your rears are at an angle and that would contribute to your hassels.
    VP Exec,Gsx-R 750
    Mar 2005
    Is your car IRS? If so, get a camber kit fitted. I have VY R8 rims on my Vp SS, with King Ultra Lows in the back, and I have not had one problem with the tyres scrubbing.
    VP SS
    Jul 2008
    yeh i got a vp ss an when i put internationals on it, it scrubbed pretty bad on the inside at the back. This may sound bad an alot of people may disagree ... but it works an no-one would ever know. Take to the inner guards with a small mash hammer, an slightly push in the area thats rubbing. You will see the tyre marks on the guard, so just focus on those areas. Try an keep it even an flat, i only spent about 10min on each side of mine, an they havnt rubbed since. Simple cost free DIY i figure. Im running ultra lows in the rear with no camber kit ... so its kinda a worst case for me, but its worked a treat. An no1 is ever ganna see it unless they pinch ya wheels lol.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by smithy46 View Post
    Thanks.
    How about getting wheels with the correct offset for your car?
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VC SLE Commodore 3.8l
    Aug 2008
    VQ Statesman 5.0 litre
    Jun 2008
    North Qld
    Hillerus is right, when you lower an IRS rear end you change the geometory of the suspension. Think of it as a pivot, the more you move the outside point up the more you will wear the inside of your tyres, you will need a camber kit to offset your lowering kit. If it was a solid axle rear end you would have no problem at all!
    Cheers................Pete!
    smithy46's Avatar
    5lt VP Calais
    Aug 2008
    haha Radalaide SA
    yeah got irs. scrubs on both sides. i had super low springs in but just recently had it raised about an inch so if there's no hassles with rubbing after installing a camber kit than that's probs the way ill go.
    would it still be worth getting vr/vs hubs?
    thanks guys much appreciated
    304 Calais
    Aug 2007
    Up your mum
    a kit should work fine, ive never seen a irs car that bad your car must of been LOW! what brand springs do you have? if there generics then the coils wont be as thick as the proper performance springs and will compress easier.
    smithy46's Avatar
    5lt VP Calais
    Aug 2008
    haha Radalaide SA
    uh there lovells springs (Australian made) i haven't heard of them before so not sure of the quality. they seem fair thick though.
  15. #15
    304 Calais
    Aug 2007
    Up your mum
    Yeah lovells have been around for years, shouldnt have an issue with them. see how the kit goes
  16. #16
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    You have a few options.
    Convert to VR hubs/control arms.
    Or get spacers and longer wheel studs.
    Spacers are illegal, but hey, your ride height probably is aswell
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
  17. #17
    smithy46's Avatar
    5lt VP Calais
    Aug 2008
    haha Radalaide SA
    oh good lol.well ill get the camber kit than and vr hubs and control arms.
    cheers guys for advice.
  18. #18
    STEALTHY™'s Avatar
    Jan 2005
    I'm using spacers. Worked a treat
    cheers sexy
  19. #19
    smithy46's Avatar
    5lt VP Calais
    Aug 2008
    haha Radalaide SA
    haha yeah i got spacers on already lol not much help there not very thick though.
  20. #20
    304 Calais
    Aug 2007
    Up your mum
    maybe thats why mine didnt scrub out, ive been running wheel spacers for a few years now.
  21. #21
    STEALTHY™'s Avatar
    Jan 2005
    I have 8mm spacers
    Make sure you get longer wheel studs tho
    cheers sexy
  22. #22
    smithy46's Avatar
    5lt VP Calais
    Aug 2008
    haha Radalaide SA
    ah yeah i don't have longer wheel studs atm and there's not alot there for the nut to screw onto .
  23. #23
    STEALTHY™'s Avatar
    Jan 2005
    Like i said to T-ROY, don't risk it.
    You can look forward to this.
    cheers sexy
  24. #24
    adam69 is offline Banned
    VT Clubby
    Oct 2004
  25. #25
    304 Calais
    Aug 2007
    Up your mum
    i use smaller spacers with the stock studs and still get enough thread to hold them on. The rims i have are aftermarket and need a small (4mm?) spacer to allow the rim to sit flush ontop of the hub
  1. VX Ute F.S rear clubsport style bar pics inside - bris sth
    By 5 speed VR in forum Parts And Other Items For Sale
    Last Post: 08-09-2007, 03:07 PM
  2. inside rear tyre where
    By xu1au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-05-2006, 07:08 PM
  3. Inside rear tyre wear on a VT
    By bc77 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2006, 08:26 AM
  4. wide rims , low car , scrubing out?????
    By jay123 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2006, 10:45 AM
  5. wheel scrape inside arch... do I have problems?
    By hildahoop in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2005, 10:07 PM
