Results 1 to 11 of 11
Thread: Flexplate to crankshaft replacement bolts
    Vp series 2
    Jun 2008
    Default Flexplate to crankshaft replacement bolts
    Anyone know were to get new flexplate to crankshaft bolts for a series2 vp?
    Only place in town is holden and they want $5 each for them.
    VP Exec,Gsx-R 750
    Mar 2005
    If they are just standard bolts, then get a length and thread type/pitch, and go to your local bolt shop.
    VP SS s2
    Jan 2007
    there high tensile bolts, if they got'em buy them coz they dont make them anymore, i just used bolts from the bolt shop and even wit heaps of loctite they come loose after a couple of months
    [DSRPTV]
    10.1:1 comp + big ass cam
    VP Exec,Gsx-R 750
    Mar 2005
    Quote Originally Posted by nori View Post
    Bolt shops sell high tensile bolts. Did you tension the bolts? I've put many truck engines together using standard high-tensile bolts that are tensioned to the correct torque, and no loctite, and haven't had any trouble.
    Vp series 2
    Jun 2008
    these are a strange tension 20nm plus 73 deg.
    The head has a big do on them not a grade.
    VP Exec,Gsx-R 750
    Mar 2005
    Quote Originally Posted by centy View Post
    Nothing strange about an angle torque. It's really up to you, if you wanna pay $5 bucks a bolt, do it, but I would be quite confident using a set of bolts from a bolt shop. If they are A/F, they would most likely be grade 8, if metric, grade 10.8
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I'm fairly confident they're not just a standard high tensile bolt. I know my flywheel -> crank bolts weren't. Whereabouts do you live? See if you can get someone to set you up with an ARP retailer.
    If not, $5 a bolt isn't so bad. At least holden can still get them for you, Holden couldn't source ANY flywheel bolts for me
    The 1972 HQ Kingswood
    VP Exec,Gsx-R 750
    Mar 2005
    Vp series 2
    Jun 2008
    I'm in bowen north QLD
    Whats so special, well if i use the wrong ones i will have some major repairs to do in a year or 2.
    I just remember from talking to reps over the years that there are different types of high tensile bolts.
    Some do not strecth so can be done up tight and others have a high shear strength.
    So you realy need to know the spec of the bolts to make sure you have the right ones.
    VP Exec,Gsx-R 750
    Mar 2005
    Some do not stretch so can be done up tight and others have a high shear strength.
    Which is what I have been saying all along. Find the grade, thread type and pitch, and get them from a bolt shop if you don't want to pay $5 a bolt. Holden aren't the only place to sell high tensile bolts!
    Vp series 2
    Jun 2008
    The bolts have a (d) marked on the head, nothing else.
    I don't know what grade d is, if you do please tell me.
  1. Flexplate bolt tension
    By centy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2008, 01:25 AM
  2. flexplate replacement
    By fishman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2008, 05:29 PM
  3. Crankshaft puller bolts
    By paulandloz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2006, 03:30 PM
  4. Now that's a Crankshaft!
    By IanG in forum The Pub
    Last Post: 06-05-2006, 10:50 PM
  5. Need Vs Vt Crankshaft
    By ADZ124 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-05-2006, 09:26 PM
