Results 1 to 6 of 6
Thread: problem with vp
    vr wagon
    Aug 2008
    nsw ulladulla
    Default problem with vp
    hi every one im new to this thing i have got a vp commdore.
    it has a standard dash i have been given a vr dash with tacho and i want to fit it to my car how can i do so or are u able to fit this to a vp.
    regards elmo
    The Darkness's Avatar
    The Darkness is offline Junk Yard Dog
    Charged VT V6 A4
    Nov 2006
    Ipswich
    think the wiring behind the cluster has to be redone. probly easier to just get an aftermarket tacho as long as there isnt a shift light if its an auto lol
    vp exec
    Dec 2006
    vaucluse, sydney
    yep the wiring between the vn/vp and vr/vs are different (from what i recall, the VN and VP are interchangeable, as are the VR and VS.
    Note also that the v6 tacho is different to the v8 so you have to make sure you buy the right one.
    i am pretty sure both differences are able to be overcome, but they are different so they arent a straight swap... pete
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    no..... the vr/vs tacho cluster IS NOT interchangable with the vn/vp...
    my mate did this and fried the vr tacho dash in his vp...poooof..lol. big time smoke show in his car.lol.
    there is something to do with the way it is wired up in the back of the cluster..
    u can use a vp cluster in a vn, but not a vr/vs..
    hope this helps..
    Vp series 2
    Jun 2008
    It is very easy to modify the dash to suit.
    Tack your old vp cluster out and and lay it face down beside the vr one. You will notice the the pin outs on the connectors ar different.
    Now remove all the light bulbs and undo the bolts and screws on the back.
    You have to remove the green film of the back of the vp one and fitt it to the vr cluster.
    They have all the wiring on it for the tacho allready.
    You will need to push a couple holes in it to suit the new gauges, then tap up the old holes and do it all back up.
    Now take the fronts of both clusters and swap them over as the warning lights are different to.
    My vp has a vn tacho and back panel in a vs cluster housing with vs speedo temp and fuel gauges and all working well.
    Charged VT V6 A4
    Nov 2006
    Ipswich
    but u can use a vr speedo and odo in a vn/vp cluster lol. easy way to fix broken odometers. centy's idea sounds good tho. they look better
  1. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. sub problem
    By naf33n in forum Car Audio
    Last Post: 18-09-2006, 01:03 PM
  4. got a gas problem help
    By SYM35 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2005, 10:25 PM
  5. Problem with car. Help!
    By wazzad in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2005, 01:37 AM
