Hey guys, bought a vp commo goin on 5-6 months ago now.
but just within this last month the car seems to shudder when its in idle, expecially at traffic lights n ****. its very annoying and worrying at the same time lol.
ALSO!!!
if anyone noes why she stalls when i kick it over and change from park to drive, park to reverse, neutral to drive, neutral to reverse, not always, but most often. if anyone noes whats goin on could you please get back to me
thanks alot
DFI unit or the coils can cause the stalling as will a dieing ECU.
Didn't vote as you missed the VN![]()
and 3 Dangerous non ABS VN's
clean out your throttle body first.
could be a sign of your CAS about to go as that was what mine was doing. Do the fault code test ans see what code it comes up with.
thanx for the reply boys, ill look into it and let yous noe wot the go is.
iam,also,having,a,problem,with,this,have,u,found,a ,soulution,yet
or,if,anyone,could,help,that,would,be,awesome
I think his space bar is broken :P
I had just had this problem fixed , if it only does it when warmed up then get your CAS replaced. I have learnt the hard way , dont get water or oil anywhere in or near the sensor as it will kill it slowly.
My CAS and fuel pump died at the same time , so try CAS and then change fuel filter.If that dont help then go onto spark plugs , plugs , injector cleaner , air filter , clean throttle body ( IAC, TPS )
Also get your fuel pressure checked ...
Thats what Ive done..
Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden![]()
