Results 1 to 17 of 17
Thread: 5L Coil Pack
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    Default 5L Coil Pack
    Can someone link me, or write up a quick step by step on replacing coil pack for a VP 5L?
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    5ltr uses a single coil, its on the firewall from memory, unbolt it, disconnect the coil plug and the wires on it, hook new one up the same way.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Yep 1 single coil, exactly wat he said ^
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    tr3nt's Avatar
    Sep 2003
    Melbourne, AU
    cheers, appreciated.. will give it a shot, got the part today.. will see how we go!!
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    you cant just unbolt it, you need to remove the engine covers, move the hoses that run along the firewall out of the way, disconnect the dissy cap, then move it out of the way, you can then have enough access to change the ***coil over.
    tr3nt's Avatar
    Sep 2003
    Melbourne, AU
    i don't think I need to change the dissy cap!? im only replacing coil pack mate....
    304 Calais
    Aug 2007
    Up your mum
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by vnv8driver View Post
    you cant just unbolt it, you need to remove the engine covers, move the hoses that run along the firewall out of the way, disconnect the dissy cap, then move it out of the way, you can then have enough access to change the dissy over.
    Ummmm you don't have to disconnect the dissy cap.
    Selling FG G6E Turbo and buying a N/A Supra
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    If its in the same spot as a VT V8 then you dont have to remove the rocker cover.
    304 Calais
    Aug 2007
    Up your mum
    ummm, you dont have to but theres pretty much no room to play with so getting it out of there is a good idea. I dont know how skinny your arms are but there is no chance in hell i can even touch the coil without removing it.
    tr3nt's Avatar
    Sep 2003
    Melbourne, AU
    hmm.. will have to have a look later!
    304 Calais
    Aug 2007
    Up your mum
    Its a tight sqeeze put it that way.
    I meant the engine covers not rocker cover, just allows more room to work with
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Trent its right at the rear of the inlet manifold on the left side. They are a bit of a prick to get to, just remove the l/h engine cover (injection, not rocker) to make it a bit easier to get to. It's just held on by a single 13mm bolt....
    Are you sure it's the coil Trent??
    304 Calais
    Aug 2007
    Up your mum
    no wonder you guys got confused, i meant to say coil instead of dissy as marked above.
  15. #15
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Should be a ten minute job, Trent Remove the passenger side fuel rail cover, then get up on your knees on the inlet manifold. This is made much more comfortable if you fold up a towel to put under your knees. I can stay up there for up to an hour at a time with a towel under my knees Very comfortable. You're a small bloke, you'll manage. Then to the right of the distributor, you'll see the coil. It's a silver cylinder, about the size of a small can of V. It helps to mark up the passenger side spark leads with numbers, unplug them, and pull them back so you can hang them off to the driver's side of the distributor. That gets those out the way.
    Then see if you can pull the heater hoses back a bit, and lift up the fuel hose. From there, there should be:
    1x wire on a blade connector, which you can slide off
    1x wire on a round terminal head, bolted on with a small nut
    1x spark lead which you can unplug
    1x 13mm bolt which you can undo with a spanner
    and then the coil should come out freely
    As long as you get your whole body up there so you can see it clearly, it's really easy
    The 1972 HQ Kingswood
  16. #16
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    ???? Talk about doing something the hard way! I just shoved the hoses out of the way and thats about it!
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  17. #17
    304 Calais
    Aug 2007
    Up your mum
    Ive seen morton and can understand, you guys must have skinny arms as well.
  1. vn coil pack
    By underthepump in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2006, 05:11 PM
  2. coil pack
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-01-2006, 03:16 PM
  3. Coil pack
    By Terfade in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2005, 09:40 AM
  4. coil pack
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2005, 02:29 PM
  5. Replacing Series I Coil Pack with Series II Coil Pack.
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 10:04 AM
