I can run the car for about 2km then it will just stop! can start it again and get about 500m then it will just stop again. this time I can turn it on and it will idol for about 3-7 seconds before it just shuts down again. it will also shut down strate away if put under any load (put in gear or even slightly touching the accelerator). I can then wait for about 20-30 minnets and it will start perfectly just to repeat the hole thing again.
there are no fault codes coming up and I have replaced the ignition packs crank angel sensor, fuel filter and the fuel pump all have had no affect.
I can hear the fuel pump working.
also the engine fan seems to be coming on all the time as well
PLEZZZZZ HELP before I burn the bloody thing to the ground!!!!!!!
any sugestions would be gratfully appreciated!!!!!!!!!!!!!!
might be a good idea to stop opening a new thread everytime and just stick to the one thread aye before a mod gets unhappy with you lol
hay buddy sorry if i ****ed anyone of havent quite grasped how update the origanal message iv sent as this is the ferst time iv used this site. no harm was intended
