Results 1 to 9 of 9
Thread: Handbrake alarm vp calais
    doms3 is offline Banned
    Vz
    Sep 2007
    Default Handbrake alarm vp calais
    I can't get the alarm to turn off have disconnected wire and still going BEEP???any Ideas ??
    VX SS M6
    Jun 2005
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    is there 7 beeps in a row?? if so its definately the handbrake chime.
    First thing i would try is reconnecting whatever wire you took off and checking the tension of the handbrake cable.
    Next would be a faulty sensor, etc.
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Vz
    Sep 2007
    Quote Originally Posted by hartsc View Post
    The wire you took off needs to be earthed for it to be "hand brake off"
    Tried that no luck
    DanVN's Avatar
    DanVN is offline Cruizin' in style!
    01 WH Statesman International 5.7L
    Nov 2007
    Western Suburbs, Vic
    is the handbrake light on on the cluster?
    if not check the 4th connector on the bottom of the cluster the handbrake wire may be broken/pulled out
    Vz
    Sep 2007
    Quote Originally Posted by DanVN View Post
    Light not on with handbrake,
    DanVN's Avatar
    Nov 2007
    Definetly sounds like the 4th connector is the culprit then... Worst comes to worst pull the chime out of the cluster and be done with it
    Vz
    Sep 2007
    So just pull the cluster out and 4th connector in?
  1. factory vn calais alarm adjustments
    By cardy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-05-2008, 09:38 PM
  2. vx calais handbrake button problem
    By dijm8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-03-2008, 01:12 AM
  3. Vr handbrake alarm sensor
    By vincent49 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2006, 09:53 PM
  4. VT Calais Alarm Set
    By mikemutlow in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-08-2005, 11:38 AM
  5. Calais Alarm/immob/keyless Entry
    By AirStrike in forum Electrical Wiring / Questions
    Last Post: 06-02-2004, 09:57 PM
