Results 1 to 6 of 6
Thread: leaking from kickdown cable
    Jun 2005
    Default leaking from kickdown cable
    having a problem with my auto. its leaking a lot of oil out of the spot where the kickdown cable connects to the auto. i changed it a couple of weeks ago. is there an o-ring that is supposed to go on the cable before i put it in? i never saw one but have read that about the t350s. any help would be good
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Jun 2005
    bump. do kickdown cables use o-rings?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    should be a bolt (about 10 mm i think) near the kickdown cable when it enters the g-box. then u have to unhook the kickdown cable and take out the O ring ...so yes there is a o ring
    Jun 2005
    hmmm, i got the bolt on, and the cable on the hook, but cant remember an o-ring. was it in the box, or the plastic holder for the cable? i didnt drop the box, so it was a tight fit to get in there so thats why i may have missed it.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    hmm well theres either a oring or a small gasket type thing there...i know theres something there otherwise the oil will leak
    could be a flat type o ring...ill check and let you know
    VP Exec
    Jun 2005
    It's been a while since I've had one apart but I think that the 'O' ring is in a groove in the plastic end of the cable.
  1. kickdown cable
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2008, 09:08 PM
  2. Kickdown cable
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2007, 01:45 PM
  3. kickdown cable and 1st gear
    By beefcream in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-04-2006, 09:11 AM
  4. EFI VK Kickdown Cable
    By fazz1977 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-01-2006, 05:01 PM
  5. VP kickdown cable
    By Namheul in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2005, 04:47 PM
