Results 1 to 4 of 4
Thread: Help!!!!!!!!!
    STR8VP's Avatar
    STR8VP is offline "doughnut king"
    S2 VQ Statesman
    Aug 2008
    Hoppers crossing
    Question Help!!!!!!!!!
    Hey every1,
    i was wondering if any1 knows how hard (if possible) it is 2 change the cluster from my vp exec (s1) to a cluster out of a vn calais(s3) both v6 please help,
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Quote Originally Posted by STR8VP View Post
    Hey every1,
    First of all, theres a sticky at the top of this very section covering all you'll need to know. Check it out sometime (or use the search)
    Its easy, and only needs a few simply wiring changed. If your not planning on using the trips, you just just put the dash straight in.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    i know you can swap s1 to s3, i think there's loom changes to be made. and i'm fairly sure the vn/vp clusters are the same.
    here's a howto on the swap itself
    Converting to a VN Calais dash
    elemeNtz is offline It's my first day :3
    responsibly
    May 2008
