Results 1 to 16 of 16
Thread: Wade Cam Dial in??
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Default Wade Cam Dial in??
    Hey guys,
    I have VN V6 and have a Wade 1250 cam and i am trying to dial it in and have no idea what im doing haha,
    I have turned the Crank to TDC and i put the cam in and lined the dots to the balance shaft and then pu the cam key on and lined the dots up on the cam and crank to TDC, i ahve a magnetic dial gauge and i hooked it all up put the lifter in and the rod, and then the dial gaunt set at 0-deg, thats as far as i got any more help i have the spec sheet aswell but cant find much on it, i've never done one before, any help is great thanx.
    ~ VN POWER ~ Click the scales
    VP Executive R-spec
    Jan 2005
    Black VN MANUAL
    Feb 2007
    Top of Vic
    I have talked to some people and some people say i cant use the stock gears and timing chain and others say i can just turn it over a tooth.
    also figure this 1 out, i took it to a performance place and they said i cant use the same gears but if i wanted to i can take the motor to them and they can put it all at TDC and have the timing chain on and thats it for $200??? its already set at TDC i can do all that crap myself not gonna pay $200 for them to stand there and look pretty.
    I talked to another person and he help me understand how to do it so i will have a crack at it, and he said if i cant get it right he will come around and dial it in for me for $80-$100 so thats not real bad i hope i can get it going right. also thanx for the website foamy.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Be kneez you need a multi keyway timing set, Dail gause in thou (or convert mm) and a degree wheel. Read the link greenfoam posted and that should help you out. There's another way that not really discuused on that site is lift @ TDC it really depends on what your cam card specs give you. Ive just finished doing mine on the motor im building. if you need anymore help let us know
    Attached Thumbnails Attached Thumbnails Wade Cam Dial in??-picture-007.jpg   Wade Cam Dial in??-picture-024.jpg   Wade Cam Dial in??-picture-025.jpg
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    If you look in the first picture that is the multikeyway on the crank gear every notch is 2 degrees advance or retard depending on which side of tdc your going.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    buy a degree wheel. most come with instructions on how to use em
    Body by Holden, Soul by Brock
    the Legend will live forever
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by immortality View Post
    Yep you should The instructions are the same as on the crow website (obviously with crow degree wheel) if you want ill hook you up with a timing set rrp is $175 i get it for $80 (series 1 may be different price unsure) degree wheel 11inch like mine is $70 i can get these for about $30 odd
    Black VN MANUAL
    Feb 2007
    Top of Vic
    So in other words there is no chance that the cam is going into the motor unless i have a adjustable timing chain set?
    Specs
    intake cam lift TDC 031
    exhaust cam lift TDC 026
    Duration @50 205
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Yes you can put it at standard timing marks but you just wont get the full potential out of it. It wont be hard later on to buy the stuff and take the timing cover off and re do it. It's just better to do it all at the one time
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Yeah i'm doing my manual conversion at the same time lol i was hopeing to put it in with the VRS gasket kit and everything, with the stock gears how can i make it all work jump a tooth? what way?
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    that may work, I dont know how much each tooth is worth but your going to need a degree wheel to get it right
    How'd you go on the stem seals? did you read my reply to that thread?
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Yeah i got your post the ones on it looked to be in good nick but i will be taking the motor down and redoing everything at a later date,this i just to get it running with the manual and charger and cam in it,
    I borrowed a crow cam degree wheel and magnetic dial gauge with mm and thou.
    Is there anychance that it could go agaist me and i could loose performance? i will save some pennys and get an adjustable one and put it in.
    Do you think it is still safe to put it in with out it havning been dialed in? or should i just put the bog stocker back in it.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    It will be ok in the stock position nothing will break or anything like that. If it is retarded a little you will loose bottom end power but gain some up top, if it was a advanced a little is will be vice versa. So in essence I'd say you'd be somewhere in between it will still be better than stock camshaft. Does the specs list the lift @ TDC? what is the duration at 50 thou? does it say how mcuh advance there is on the cam?
    If i were you instead of mucfking around with the chain i'd just leave it in the stock timing position Then when you save enough get a gearset and dail it in properly
    EDit stock actually has no advance i was reading my sheet wrong Sorry
    Black VN MANUAL
    Feb 2007
    Top of Vic
    intake cam lift @ TDC 031
    Exhaust cam lift @TDC 026
    Cam lift 281
    Duration adv 264
    duration @ 50 205
    and yeah, i will go and do it all now see how i go i will just leave it at stock specs and put it in thanx for your help.
  15. #15
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Thats smaller than the stage 3 crow i put in... is that the one you had for sale? put it in then check you lift at TDC 31 thou is minmum spec you can be up to 5 thou higher. So id say if its somewhere in the 20-40 range it should be ok
  16. #16
    Black VN MANUAL
    Feb 2007
    Top of Vic
    i didnt want a big cam in it cause it is supercharged and i am going to be upping the boost, i did the degree wheel and it cam up 13 and 12.
LinkBacks (?)
  1. VN Dial Template
    By GIMPY1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-08-2008, 07:15 PM
  2. Replies: 0
    Last Post: 21-08-2008, 03:56 PM
  3. wade 992a with boost?
    By cracker in forum V6 Development And Modification
    Last Post: 09-07-2008, 04:06 PM
  4. vn wade cam into vr
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2008, 10:16 AM
  5. Wade 992a issues
    By aokman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-05-2006, 02:38 PM
