whats the best way to tint my tail lights, i want them pretty dark, but legal at the same time, if thats possable?, ahah
if not, i dont care...
vht night shades is made for the job but is dark, very dark and you need a clear gloss over the top.
Or get some clear and tint it a little spray it on, this may be legal.
how much would the nightshade and clear coat be?
what kind of clear coat you reckon?
the legality if i recall is that they have to be all visible from 20 metres away, day or night.
vht do a clear coat as well, the nightshades probably specifies on the back of the can what product is best to go over the top.
good luck with it man
I bought a can of it the other day 4 16 bux from autobarn. I didnt put a clear coat on it only cause im puttin another coat on it 2moro if the weather is good
Wrecking VL factory V8 only a few bits left still have full dash/crash pad
and have a vk 202 motor and 5 speed Make an offer want it gone
If you want it pretty dark its not going to be legal, i sprayed mine pretty dark and turns out abit rough but i went over it with some polish and it fixed it all up and made it smooth
$14-$16 for the night shades and not sure on the clear i didnt use it but should be about the same and you will only need 1 can.
~ VN POWER ~ Click the scales
Its 200 metres (not sure if it was a typo pow3rslave)
Its only dark depending how you apply it. 2 Light coats should be plenty, and just get a pressure pack clear from the same place. If i do mine later today, i might do a how to for ya's.
Originally Posted by davway
dont use night shades man get your panel beater to spray them in 2pak...
bit of black in some clear makes them dark yet allowing maxim light to get through and they will stay shiny unlike night shades.
these are mine which i did myself and thats just parkers not brake lights which would be brighter again.
my VN Berlina :)
ive tinted mine with nightshades came out perfect! 2-3 coats and still good asu only need 1 can it will have heaps in it left still
you need to sand the tails lights first with 1000-then 2000- then 3000grit wet till u get it all smooth grr took me like n hour for both :P
after ur finished make sure u clean everythings off it so theres no dirt etc.., dont know what the stuffs called, lol but i just used windex i didnt care i was just mucking around with my spare lights (came out good TO so i used them) , spray 1 coat on both.. oh yea make sure u tint both of them at the same time so they look the same!
then every 5-10mins add 2more coats let them dry for about a full day
im not sure what u do after this mite sound dumb but i never clear coated mine.. do u sand it with 3000 grit then clear coat??
my explaining mite be crap but i did my best to explainciaooo
oh by the way mines legal too.. got pulled over many times(not happy about) but they never said anything about my lights nor did the rwc supplier wen i had 2 canarys![]()
h0Ld3n`VN,
ill defiantly try this ay, but ill clear coat it at the end..,
bit of a waste of money since you only use some of the can, but i spose its worth it![]()
love your tail lights mate,
hopefully mine will turn out like this haha
Heres a few of mine.
If your worries about doing them too dark and being illegal, try something like these.
wadeo it is worth the money.. changes the looks heapsoh n i tinted my garnish to, so i used allmost the whole can
stealthy your calais is so nice :P gime gime
