Results 1 to 16 of 16
Thread: Vq issues
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Default Vq issues
    Hey all, My vq 5ltr is having issues, I start her up an the alternator isn't charging....
    I replaced the regulator on the alternator still no luck, checked EVERYTHING else an still no luck, even bashed teh alternator with a hammer to see if it had loose windings to weld back together....
    Does this mean i'm up for an alternator, It happened all of a sudden too...
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    VQ STATESMAN
    May 2006
    I had some trouble with mine ended up being this little plastic clip near the battery that supplies the power (or signal) to the alternator cost about $5 to fix.
    Its standard height i swear officer get your tape and check :-)......... pump up faster god dam you!!!
    Check out my Stato
    http://forums.justcommodores.com.au/...ad.php?t=32773
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by THE STATESMAN View Post
    Able to provide any more information about this??? Would greatly appreciate it..
    MaT
    VP Executive R-spec
    Jan 2005
    Hozy it's a ?????brown???? wire that's the signal wire that goes from the alternator to the battery, it'll be broken off. It's happened to me before and it wont charge without it
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by greenfoam View Post
    Can i patch the brown wire by itself straight from alternator to the battery?
    its like a dirty white/browny color...
    I'll check it out 2morrow it's started to rain....
    I hope so badly its just that...
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Put the guts of an old vn v6 85amp alternator in my vn v8 85amp alternator housing... works beautifully!!!!
    switched the front fan/bearing/pulley setup aswell..
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    This was my exact problem too, pull it off and reconnect it.
    DanVN's Avatar
    DanVN is offline Cruizin' in style!
    01 WH Statesman International 5.7L
    Nov 2007
    Western Suburbs, Vic
    Took me 2 months to find that damn brown wire... nobody knew what it was when i was trying to fix it
    VP Executive R-spec
    Jan 2005
    DanVN, I bought a new battery before I found it so you weren't the only sucker
    DanVN's Avatar
    Nov 2007
    We Spent 2 months, 3 alternators 2 batterys and multiple throwing a hammer at the car and giving up before i went, Hey Wtf does this wire go!
    Luckily the (insert random unliked family member comment) paid for all that stuff before he gave up and gave the car to me
    VQ STATESMAN
    May 2006
    I went through 1 standard 85amp alternator that didnt work so i got a 120amp and then an odessey battery. Then found out it was that stupid little wire
    Check out my Stato
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    ok well, same issue i had before that led to burning alternator out!!
    if i sit 4500-5000rpm i'll spin a belt clean off the crank/wpump/alt.. Doesnt matter if its new or old belt, did it before aswell with the v8 alternator...
    MaT
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Quote Originally Posted by HoZy View Post
    if i sit 4500-5500rpm & bounce limiter say once or twice i'll spin a belt clean off the crank/wpump/alt.. Doesnt matter if its new or old belt, did it before aswell with the v8 alternator...
    Far out man, you've had this car how long? I havn't even found the limiter on my VQ yet In fact, I don't think I've even touched 5000rpm yet!!
    The 1972 HQ Kingswood
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    is the alternator pulley aligned with the rest of the pulleys? also if its under alot of strain it will try and twist the alternator downwards which throws the belt.... i used to ahve alot of problems with my powersteering doing this at high revs......
  15. #15
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by Peanuts Inc. View Post
    mmmm yeah i've seen your beast at high revs... My old vq used to be fine, oh well off to get another belt, workin on my car on my 20th b'day hehe lol
    cheers
    mat
  16. #16
    1992 VQII Statesman
    Sep 2008
    need to change the engine belts on my VQ V8. (fraying, cracked a bit) how do i go about doing this after buying the required belts?
    1992 VQII Statesman
    1991 VP Calais/ 1992 VP Calais
    1992 VPII Vacationer Wagon
  1. VZ Issues
    By tigerpm7 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-05-2008, 06:40 PM
  2. T5 issues
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2008, 10:01 AM
  3. VN tow bar issues
    By timmy_tam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2007, 10:30 PM
  4. VL issues - please help
    By hobnog in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-03-2006, 08:54 PM
  5. Issues
    By PhatVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2005, 09:19 PM
