Results 1 to 11 of 11
Thread: How to bleed your coolant system vp
    Vp series 2
    Jun 2008
    Default How to bleed your coolant system vp
    If you want to get all the air out of your coolant system then.
    1. You take the overflow cap of and stick the tube inside the end of your garden hose.
    2. Turn the hose on slowly and then crack off the bleeder valve on the thermo stat housing.
    3. When a full stream of fluid comes out do up the valve and you are all ready to roll. after you replace thwe cap.
    this can also be done with a large coke bottle.
    1. You fill the coke bottle right to the top.
    2. Fill the radiator as much as you can with a hose or bucket.
    3. Open the bleed valve on the thermostat housing.
    4. Shove the top of the coke bottle into the radiator cap hole.
    5. While pressing the bottle down squeeze till coolant comes out of the bleed valve.
    6. Quickly do up the valve and replace the radiator cap.
    After a little run when the system gets pressure in it open the valve to let the last little bit of air out.
    There are other ways but this is how i tend to do it.
    NO CAR ATM.. -.-
    Jul 2006
    if u want there air to go out, my dad taught me how..
    bleed the coolant/water
    fill up full
    leave the bottle/radiator cap off
    start the car leave on for about 5mins
    and it starts sucking the water so u just keep adding till it doesnt suck it up nomore oh and ofcourse dont forget to put the cap back on haha :P
    VP ute
    Mar 2006
    I cut the top off a coolant bottle and stuffed a slice of radiator hose over it. That jams into the top of the radiator. First I fill the system with the bleed valve open and top hose off. then when the coolant comes out, conect the top hose and fill. then tighten the bleed valve and shove in the coolant bottle. Fill that with coolant and run the car with varing revs over 3 or 4 times of the thermostat comeing on and off. The air really bubbles out for ages. This way you will get every bit out. all of it. then I remove the coolant bottle carefully because it will be hot and top up if needed just a smidge and whack the cap on. then top up the overflow bottle.
    A guy from Holden taught me that. (he used a purpose made funnel that screwed into top of the radiator.)
    May 2008
    Default rad overflowing
    what if your rad starts overflowing when the thermostat opens up? is this normal or is there something wrong with my cooling system?
    Vp series 2
    Jun 2008
    As the water heats up it expands so over flowing while running with cap of is normal.
    The boiling temp for a commodore system ibn good nick is VERY high.
    The cap holds pressure in and for ever psi i think the boiling point goes up 5 degrees.
    So a commodore system can get very hot.
    May 2008
    Default bleeding
    thanks mate!, the reason I was asking is because when the car is running and the bleed screw is open no coolant flows no matter how long I leave it. Also as I let it run the coolant starts to creep out of the rad. However, when I give it throttle or when the thermo is open I do get coolant coming out the bleed screw. I ask because a lot of the posts say to keep the cap off until the thermo opens in their how to's for bleeding the air out. I can also hear gurgling behind the dash when the heaters on, makes me think air in the system.
    thanks again
    VP ute
    Mar 2006
    use my method and kiss the gurgling good bye.
    I didn't mention that when you shove the coolant bottle in the top you have to fill it up a bit so all the air bubbles to the highest point in the system. When the thermo opens the first time there will be a stack of bubbling and the level drops so have some next to you. I also wear gloves because of the heat of the coolant. I have to support the bottle at the upsidedown handle because the vibrations can make it fall off. Hold it and it will be fine. takes about 30 mins if you really go to town on it
    Vp series 2
    Jun 2008
    the blled nipple is higher then the rad cap so will not flow out of there without assistance.
    Thermo stats have a small bbypass hole in them to let a little fluid past all the time, so air gets past.
    Always good idea to bleed again after a run, i do.
    normally get a little air out but not much.
    Hose on the over flow spout is easiest and cleanest way to do it.
    You don't get covered in chrap just before you go out.
    VP ute
    Mar 2006
    yeah it is normally higher but once you fit the container up to the cap and fill it with coolant it is way higher than the bleed screw.
    vscom88's Avatar
    vscom88 is offline Andrew-
    VS 5speed
    Dec 2008
    i started a coolant flush and kept bleeding the system but it gets really hot (half way) and spits all the water back, i have the heater on and everything but it still throws the water back and the thermo fans wont kick in? how can i get the fan to kick in, i recently just fixed a relay issue with the fan
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    With the bleed valve on the thermostat housing: It won't push anything out unless the cooling system is sealed, the idea behind that is to warm the car up fully (with the rad cap on, and the heater on full), nip open the bleed screw, let it dribble until there are no more air bubbles, do it back up. Then top up the overflow bottle accordingly.
LinkBacks (?)
  1. bleed valve location for cooling system
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-03-2010, 07:19 PM
  2. Oil in coolant system
    By marco2768 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2007, 09:52 PM
  3. Bleeding coolant system
    By coolvxss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2006, 05:25 PM
  4. How Would I Go On Flushing My Coolant System?
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2006, 01:32 PM
  5. VR 5.0L coolant bleed valve
    By mess666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2006, 11:22 AM
