Results 1 to 6 of 6
Thread: Vn Missfire
    VN
    Dec 2005
    Default Vn Missfire
    Hey guys, the ever reliable vn v6 series II has developed a misfire and I am not quite sure why. I have read the other posts and checked the leads, they all read similar values of resistance with longer leads being slightly higher.
    I measure across the tops of the coil packs and they all read around 6 kohms, is that normal?
    If I only lightly touch the throttle is goes ok, but if I sink the boot in it misfires and runs like crap, plus it starts to smell like petrol.
    Sometimes it will run perfectly fine.
    Any ideas??
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    You have checked your leads/spark, then im leaning towards a fuel issue. Get your injectors cleaned or get reconditioned ones, maybe your fuel pressure reg is on its way out? When was the last time you changed your fuel filter?
    89 vn commerdoor
    Sep 2008
    hi im haveing problems with my 89 vn commerdoor it starts sluggish it turns over fine but takes a while to start longer then it use too i changed the leads spark plugs and bought a new battery with cost me about 250$ and im still haveing the same problem...if im drivein it and i stop and start it again its fine just when its been sitting there for a few hours it starts up the crap again hahah umm i was thinging it could be the fuel pump about too die or injecters are dirty so if anyone has some answers please send em in cheers ....onslaught
    VN
    Dec 2005
    Quote Originally Posted by Mack View Post
    It sort of backfires too, so I am leaning away from any fuel related issue.
    It's not a big backfire, more of a pop if that makes any sense.
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Check your ecu for any error codes, sometimes comes up with some useful info.
    Gravity is proof that nature keeps getting us down.
    azz
    azz is offline azz
    vp wagon
    May 2008
    maryborough
    i had the same symtoms check around both sides of the block for what feels like an exhaust leak cause it might be a blown head gasket if you feel a exhaust leak do a compression test and go from there and also check for a cracked exhaust mannifold
  1. Missfire & rev counter fluctuation
    By barracuda in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2009, 05:38 AM
  2. random missfire
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2007, 04:02 PM
  3. Missfire at idle...
    By Sorak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2006, 10:09 AM
  4. VL missfire losing power
    By STYALR in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-06-2006, 06:56 PM
  5. Vs Missfire
    By Chris Everett in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2004, 05:56 PM
