Results 1 to 4 of 4
Thread: Code 33 - Manifold Absolute Pressure Sensor (MAP) - Voltage Too High
    NO CAR ATM.. -.-
    Jul 2006
    Default Code 33 - Manifold Absolute Pressure Sensor (MAP) - Voltage Too High
    hey peoples i thought i would of done a check and i got this code 33, has anyone got this code n fixed it.. help would be appreciatedddd
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by h0Ld3n`VN View Post
    Is the sensor connector in good nic? (corrosion)
    and 3 Dangerous non ABS VN's
    02' VX Berlina 5.7L
    Feb 2005
    S.E Melb
    Check the hose that goes from the throttle body to the MAP sensor. I had this problem also, andit was a cracked hose in the end.
    NO CAR ATM.. -.-
    Jul 2006
    has no corrison.. i think it could be the hose duno ill try it out n post back, thanks.
  1. Code 15 - Coolant temperature Sensor - Voltage Too High
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-03-2008, 12:42 AM
  2. code 22 Throttle Position Sensor low voltage
    By boults_4545 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-07-2006, 04:47 PM
  3. Code 53 - System Voltage high (auto)
    By willy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2006, 01:04 PM
  4. Code 16 - Coolant temperature Sensor voltage unstable ???
    By nathsvrbt1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2006, 01:00 PM
  5. Error 33 - MAP Sensor voltage high / vacuum leak
    By shaggerz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2005, 09:06 AM
