Results 1 to 24 of 24
Thread: Heel and toe
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Question Heel and toe
    One of the joys of driving manual, is the ability to downshift while braking, in preparation for a corner, instead of having to wait 'till you mash the throttle to find second gear
    One of the not-joys of driving my manual VQ, is the inability to heel or side-step the accelerator consistently while braking, due to its inconvenient proximity as pictured below:
    To all you T5 drivers out there, is your accelerator this far to the right? Or is there a different manual accelerator bar?
    I want to move the throttle about an inch closer to the brake pedal Any bright ideas out there in those big 'ole brains around JC?
    Short of being able to pick up any bolt-ons, I would have to take the actual pedal assembly somewhere, for someone to bend it into a more convenient shape. If I had to do this, would anybody know a good place to start asking?
    Just putting all of this out there - feel free to suggest anything at all! (except bigger feet. I can't get bigger feet.)
    The 1972 HQ Kingswood
    Vp series 2
    Jun 2008
    mate it would not be hard to do your self wihout and special skill as long as do do not mind it being a little lower. with some skill and tolls the same height.
    remove from car
    straighten the kinks out a little to move it accross.
    This will make it lower, not an ideal fix.
    same thing but either cut a bit out of the shaft and weld back together, a sleeve over the join would make it stronger.
    Or you could just straighten it and then cut some of the bottem and then reshape the bottom back to the original to fit the pedal.
    Another method would be to get some of the dressup pdeal that go over you originals as the will make them closer together.
    VE SSV Sportswagon, VK race car, Kwaka ZX12R!
    Oct 2003
    Bayside Melbourne
    with a bit of work...and a bit of patience you can get 'em nice and close
    like on the race car
    also did the same on the SS
    hth
    Smitty
    Smitty...with the VE SSv SII Sportswagon, VK race car and... Kwaka ZX12R
    VL, VH V8 wag, Zook Vitara.
    Apr 2005
    Ardlethan, NSW
    turn the accelerator pedal sideways...
    Need some parts for my VH 253:
    Green standard steering wheel...Green lower B-pillar covers.
    Green sunglasses holder/lower dash bits...Air-con and assorted engine bay parts.
    PM with any info.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    If your looking to get it bent to desire angle see an engineering workshop theyll be able to do that in 5mins with an oxy and the re-harden at the same time. Smitty looks like you bent the brake pedal instead of accelerator. Have you tried flatshifting yet morton? another one of the joys of manuals
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Aug 2008
    Quote Originally Posted by Stretchomatic View Post
    or just make the whole pedal bigger
    Apr 2005
    Ardlethan, NSW
    haha or that...pretty sure theres legalities for our ideas...
    definitely see if u can cut and weld or get an engineering place to do it...
    PM with any info.
    VN Wagon
    Feb 2005
    I measured the distance between the brake pedal and the accelerator. Mine is 75mm and I normally do heel and toe but I do need to twist my foot a bit.
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    it may just be that u have an auto accelerator pedal, and a manual pedal box..duh!!!!lol
    u should be able to bend it over to the left a fair bit, as if ur turnin the pedal at the bottom.. but, as PUB24/7 mentioned earlier, it might be better [for legalities], to consult an engineer first bro... in case there is major problems later..
    i.e. broken pedal, unneccessary pedal twisting...
    or u could go to wreckers, and get another pedal from another manual shell....
    rawsonn is offline wants to know more
    VN Berlina
    Aug 2008
    Goonellabah, NSW
    i would definatly see a engineeer first mate .... will prob need a engineers cert for roadworthy anyways
    i love freedom of speach because [ details deleted by moderator]
    '76 HJ RB25DET Ute
    Feb 2007
    Black VN MANUAL
    Feb 2007
    Top of Vic
    I dont think mine is that far apart either, if it was me i would cut abit of it and bend it into shape and if i stuffed up i would hit up the wreckers there might be different types.
    ~ VN POWER ~ Click the scales
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I'm not saying see an engineer i doubt anyone would ever notice it being bent 50mm to one side there's isnt any sort of huge load on a pedal which would cause a peice of metal that thick to break. I suggested a engineering workshop as they'd have the right tools to bend it properly but all you'll need is an oxy and some oil to harden the metal in. I suggest removing it from the car before heating it with an oxy
    VN Wagon
    Feb 2005
    Wow, it looks pretty far on my car too! (Manual from the factory)
  15. #15
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
  16. #16
    Nov 2007
    Quote Originally Posted by TurboXS (Pete) View Post
    maybe, but urs aint as wide apart as mortons.....
    urs is closer by heaps...
  17. #17
    Morton's Avatar
    May 2006
    Thanks for all the input fellas I think the idea here may be to grab a second pedal from a wreckers, and have a fiddle with that. See what magic I can perform Will allow for swaps when it comes roadworthy time if it looks particularly suss, aswell as other obvious conveniences.
    But first, I'll try sticking it in a vice and hitting it lots. That always makes things bend
  18. #18
    Morton's Avatar
    May 2006
    Quote Originally Posted by Smitty View Post
    hth
    Smitty
    Yeah yours looks nuts That's a good distance for heel action
    Quote Originally Posted by Pub24/7 View Post
    Yeah, that would probably be the best idea "engineering workshop" eh? what would a place like this be called? How would I find one? Presumably not under "engineering workshops" in the yellow pages I have absolutely no idea about these things
    And no, no flat shifting yet
    Quote Originally Posted by hjtrbo View Post
    Left foot brake and pretend you gotta dog box.
    LOL, maybe if things get desperate. For now I think I'll keep my synchros though
    Yeah, yours isn't ideal either.
    Quote Originally Posted by NV_90VN View Post
  19. #19
    Vp series 2
    Jun 2008
    another idea, just get a wider foot.
    I have an auto and the opposite problem.
    hit the brake and the gas at the same time.
  20. #20
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Most are called things like Southport engineering, peirce engineering jack's engineering not too imaganitive are they? look up engineers/engineering in the yellow pages there be plenty listed there. Just when you talk to them or go in (which is what i think is better) it helps if you have a clear idea or drawing of what you want done. like for instance saying it must maintain its current length and angle but but moved an inch to left or right.
    I think the brake pedal should be the one you get done i remember with my work boots on sometimes id hit the clutch as they were pretty close together
  21. #21
    Jul 2008
    Mine is about the same as in the pics, i just twist my foor a bit and brake with my big toe and accelerate with the side/heal of my foot.
    I find it helps tremenusly with the old box in my vp to get a very smooth change with minimal clutch wear if you can match the revs perfectly, takes practice but can be done.
    Also sounds dam sweet when you nail it. ( used to do nothing but heal toe in my astra prob ony reason box and clutch lasted 130k before i got rid of it )
    Ohhh its also good for a dodgy syncro But If they are complety gone double clutching is a must, and thats a whole other kettle of fish.
    Flat shifting, do that if you hate your gear box, wont last to long esp on these weak T5's. In the time ive had mine ive killed reverse and the change from 1st to 2nd is a bit notchy and i havent flat shifted it yet !
  22. #22
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    mine seems fine to me, but when i put the new pedals on mine, the accelerator was rubbing on the kick panel for a bit, i ended up shifting it over a bit.
  23. #23
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
  24. #24
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    See mine arnt that far apart... but i also have aftermarket pedals... that and really big feet and consequently shoes
    that and i tend to use the left part of the shoe for braking and the right for acc when downshifting.. could never bend my foot in such a way to heel and toe properly...
    aZk.
