Results 1 to 7 of 7
Thread: removing dash in vn
    rawsonn is offline wants to know more
    VN Berlina
    Aug 2008
    Goonellabah, NSW
    Default removing dash in vn
    i want to take my dsah out and give it a new coat on nice black vinal paint but im abit unsure on how to do it anyone know of any good guides with or without pics that might help me along?
    thanks in advance
    i love freedom of speach because [ details deleted by moderator]
    Morton's Avatar
    Fairstar the Funship
    May 2006
    yeah, if you have a search through the how-to section, there's a few guides that cover a lot of the steps
    the rest is pretty much just finding stuff that gets in the way, and unscrewing it Just keep all screws and nuts and bolts in labelled containers so you know what goes where when it's time to re-assemble
    The 1972 HQ Kingswood
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Did it over the weekend just gone. You best start by removing the centre console by taking the atuo selector plate part off with console out move onto the radio surround area. With that removed take the glove box and lower panels off under both sides of dash. Its all pretty basic look for screws and undo it all.
    The main dash you start by removing instrument culuster and surround and steering column sourround easier with the steering wheel off but i got by by dropping the steering column down then the main pad start from the side first remove cover plates then air vents. Remove speaker covers then there are four screws in the demister vents then some bolts underneath that and thats it all pretty much done
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Have you got a Gregorys manual???
    That thing is worth it's weight in gold. It'll tell you step by step, how to remove your dash and it will have pictures too.
    (I know we all like pictures, it tells us that the stupid part that won't come off, actully can)
    But thats another story. Go buy one off ebay, costs you like $10. It's well worth it.
    VN calais 91
    Aug 2005
    i woudln't really recommond it
    i took mine apart once becuaes the heater controls didn't switch between face and feet, turned out to be missing the VAC ball in the engine bay
    taking it out was a massive bitch, and i'm car literate with a gregories.
    its heavy, some parts are brittle, some are hard to get to. wiring runs all over the place
    i got mine back in, and now it sits about 1 cm from where its suppose to.....
    i'd just paint it as it is in the car.....
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    I've had mine out 3 times and never had issues getting it back where it goes. First time I put it back in it had a rattle but havent had that since so not sure what that was.
    VN Berlina
    Aug 2008
    Goonellabah, NSW
    Quote Originally Posted by timmy_tam View Post
    well i got it out in about 20mins using a gregorys manual easy as but as for the above comment on spraying it inside the car ahhhh no thanks
    EDIT: got it back in after the coats of vinal black no gaps all lined up good, everything works
  1. removing dash
    By slappa. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2008, 09:47 PM
  2. HELP!!! Removing dash out of mmy vs. Need help a.s.a.p!
    By 02QIK in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2007, 10:04 PM
  3. removing dash... HOW DO I!!
    By nmj in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-06-2006, 11:11 PM
  4. Removing dash in VN
    By vnberlwagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2006, 11:59 PM
  5. removing the dash in a vk?
    By V-ahhh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-01-2006, 08:38 PM
