Hey all i was just wondering if the t5 would bolt up to an ecotec motor, cause i love my 5 speed but my motor is dying a slow slow death and i want to replace it with an ecotec.
any info is greatly appreciated.
cheers
Busta-P
no it wont
Edit: dissregaurd me, im must have been on drugs yesterday.
And why not exactly, aren't both motors turbo pattern?, this is a serious question by the way.
cheers
Busta-P
It will, but I'm not sure as to the bellhousing, you might need one of a VS if bolting to an ecotec. I'm not 100% sure about that.
should fit fine? hozy got a vn auto onto his ecotec
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
so long as its not an early VN t5 it will fit. Im told the Series 1 VN manuals had a different imput shaft. VN 2 up to VS 1 T5's are the same.
My gearbox is a VN series 2 t5
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
Pretty sure all T5's are the same
mine is a 90' model so i think it's series 2 vn so i guess everything should be fine then. thanks for the input guys it hax been more than helpful.
cheers
Busta-P
I'd imagine the t5 will bolt up, but you might possibly run into issues with the flywheel.
I believe ecotecs used a different flywheel to the earlier v6's - the best person to PM about this would be 'thestig' as I believe he's put a ecotec flywheel behind a early v6 and had to do some machining etc before it would all fit up with his t5.
you might just be able to bolt the earlier flywheel onto the ecotec though, maybe!
oh yeah. the fly wheel is an issue. also, i think 1990 was like a series 1.5 model, so im not sure what engine you would have
it's definitely the same as a vp or vr ser 1 motor, i sold my other 90 model 5 speed to a fella with a vr and he didn't have any probs.
another question bout that will the t5 bolt up to any series 2 buick engine or is there a specific manual buick engine
IF ITS GOT TITS OR WHEELS ITS GONNA COST YOU.. ESPECIALLY IF THEY ARE BIG TITS AND BIG MOTORS
MY DAILY NOW WITH ECOTEC CONVERSION
http://forums.justcommodores.com.au/...ml#post2145177
t5 box is essentially the same throughout the v6 range..
only thing that changed were flywheels essentially (aside from vn s1 had a different balencing weight)
vn s1 had a 6 bolt flywheel
vn s2-vr had an 8 bolt flywheel.
vs s1 (t5) had an 8 bolt flywheel counterbalenced to that of the vn-vr variety..
if you have a vn-vr flywheel go to your machine shop with your auto flexplate from the motor the t5 will be going on and get them to mirror balence it.
all t5's have the same input shaft- therefor the same spigot bush.
and im sorry i don't know the entire stories with the starter motors.. there is a difference with starter motors for at least one of the models.
dig dig dig dig
haha true... didn't even see the date.. till just then! LOL
@ Vammplestat.
This isn't a thread dig, this is actually how information should be acheived.
By searching for an old thread and either finding the info you need or asking a relevant question as the gentleman above has.
Please learn the difference between digging and the correct way to ask for info, this way we might not end up with as many rediculous exhasut threads.
Peace out.
97 WRX AWD
Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
Turbosmart dual stage boost controller
IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
BP98 safe tune @ 171.8awkw
