HAS ANY ONE HAD/SOLVED THIS PROB B4? LOVE SOME TROUBLESHOOTING PLEASE ALL ELECTRICS WORKING FINE CHANGED FUSES CHANGED BUTTONS STILL NO MOVEMENT IN WINDOWS CHECKED MYFUSE BOX HAVE +POWER TO BOTH SIDE OF THE FUSE SO IM GUESSING THERE IS A FAULT IN THE CONNECTION?? LOVE SOME CONTACT COS IM A SHOCKING ELECTRICIAN AND IM NOT WANT DODGY HOOK UPS IN MY ORIGINAL![]()
well, could be the motors for the power windows but im guessing its probably the switches for the power windows.
Pull them out of your console, just pull them up gently and ensure all cables are connected properly to the switch, if so check they are getting power to them. if thats all fine, might have to look into the power window motors
I didnt know that VN SS's came with power windows?
no they had the option of all 4 electric windows
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
bridge the wiring that plugs into the switches and see if the windows move, if they do its your switches.
I have a 89 Berlina Wagon and all the power windows work except for the driver side, does anyone know if this is common? When I press the button, a clicking sound comes from the black box thing where they are wired up, but all the other windows work and they dont click, help i need a ROADWORTHY!![]()
check a different set of switches and if that dosent work id say its your window reg
its your window motor. you can unscrew the motor from the mechanism to swap. can be a bit hard to get the new one in. i had the same problem last week. to test its your motor, you can just take off your door trim and hook 12 volts directly to the motor
I wouldnt have a clue, but the clicking is coming from the power supply, not the door or window, so what the hell does that mean??
Ya see, the driver window doesnt work at all the motor doesnt make a noise but when buttons are pressed the black box where the fuse is clicks but nothing, does that help or did u know all that before? lol sorry cobba but any help would be great
same thing happened to me. was fixed by changing the motor. i had the same clicking noises
Thanks champ ill see if the motor works 2moro!![]()
have no power in ANY windows motors are good unless they have all busted ..... changed all fuses ...have power to all fuses ...short some where between ignition and the console switches is there a fuses hidden?? damn electrics an ss convirtable would be killalol betta sleep on that cheers guys
hehe 2 of my power windows wind down a fractions the other do dont work at all and one of those that does wind down doesnt wind back up...... ideas
My problem is the windows were working then the fuse blew and after replacing the fuse they now have no power going to the switches. Is it possible that the wiring got fried when the fuse blew? Very frustrating as i dont know where to go from here
G M O
