Results 1 to 17 of 17
Thread: Letting VN sit for 2+ days, MUCH faster!?!
    VN1 Auto V6
    Dec 2004
    Default Letting VN sit for 2+ days, MUCH faster!?!
    Hey all!
    There isnt really much i can say in my first post on the subject, other then that if i drive my S1 VN (no mods except a VP LE memcal.. if thats even counted as one :S.. oh and its auto, 230,000kms) every day its fine to drive no real problem sother then a pretty rough vibration in the cabin.. Although if i start her up after abotu 2 days.. the car will take awhile to reverse when put into reverse gear.. thats ok i can deal with that
    but
    i also notice that when i get a chance to put my foot down just to get to 60, good god i only have to lightly touch the throttle and it starts to fly.. its really bizzare :S.. It even scared me about 5 mins ago turning off a main road, i would put my foot down to where i usually would when driving and it started to kick out.. i was close to ****ting myself lol The engine note is noticeably throatier? and just overall sounds much better.
    Anyway what i wanted to ask you guys.girls is what could possibly cause something like this? I can only think of some sort of fluid issue... although i have no idea WHAT ??
    Aug 2008
    HAZZA-VN's Avatar
    HAZZA-VN is offline License back 11/02/2011
    5litre Calais
    Apr 2008
    Its all in ur head lol,
    Speed never killed anyone. Suddenly becoming stationary, now that's what gets you...
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    I sell cheap acid PM me!!
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VP Executive R-spec
    Jan 2005
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    any difference in temperature when it goes better then normally?
    VN1 Auto V6
    Dec 2004
    actually the temp when up alot faster then normal.. I have replaced the thermostat housing + thermostat with brand new items about 3 weeks ago.
    I have had a nagging issue where the thermofan would turn on at different intervals at the temp gauge.
    For example the gauge would be at 1/4 but the fans would kick in, whilst usually it takes the fans to kick in when the gauge gets to about 1/2.
    Also it takes ages for the heater to actually get warm.. It all sounds as if the thermostat was stuck or there was nothing there, but i assure you it ahs been changed with a new one lol Oh and you can also hear water trickling behind the heater, but just figured it was somethign to do with the heating (obviously) and probably just meant to be lik ethat.
    Haha and to you guys saying its aplacebo thing i totally understand what your saying lol but i am 10000% its not that, because the reason i have been swapping memcals was due to a mechanic sharing his opinion that it was the ecu that was making the engine idle rough..
    I ran an ecu check and nothing pops up??
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    maybe you have air still in your cooling system, would explaning the water noises.
    i would flush the cooling system thoughly and make sure the heater is open/on full so it flushes properly, maybe add some flushing additive (dont know whats out there) and fun that for a bit, then again flush, and fill with coolent, ensuring all air is bleed from the system.
    VQ Statesman 5.0 litre
    Jun 2008
    North Qld
    Clean the oxygen sensor up to fix your rough idling and your cooling system sounds like it is full of air?
    As for the huge power surge?.....how the faaaark do i get one?????? & why complain about it?????????
    Cheers..................Pete!
    VN1 Auto V6
    Dec 2004
    im not complaining, haha i just want to know why the hell it would suddenly happen after letting the car sit for a few days??
    Im just interested to know what could cause this, and tomorrow if i go to drive her.. and she goes back to normal .. i want to know what is wrong with it so i can get her like that all the time lol
    I will look into the o2 sensor + curcuit and also flush and drain the air/coolant from the radiator. If it works you will hear about it haha id be stoked
    Vp series 2
    Jun 2008
    does the car use oil?
    An old trick i have heard that may have something to do with what is happening, provided it uses a little oil.
    When valve guide seals are stuffed the oil leaks down, if over 2 days it is leaking anf getting into the pots there is a possibility that the oil is getting onto the old compession rings and making them seal better and giving you more power for a little while.
    I have heard stories of old bushies with realy rs engines putting a pump from a grease gun in 1 failing pot each morning to seal it and make the engine run ok.
    this is about the only thing i can think off that may explain it.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by greenfoam View Post
    It will go better with a series one memcal in it too
    He's right, you've just electronically made your car slower.
    s1 tune is fine on the s1 motor, if it's not then you need to maintain that motor better.
    Sam
    WTB: mulberry VN interior parts
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Could possibly be the auto on its way out, and starting to slip. It would explain the intermittant power loss when its playing up.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by savage1987 View Post
    Sam
    lol its the same bloody motor, just a pussier cam and better balancing on the s2
    it honostly dosnt matter!!!!!!!!!!!!!!!!!!!!!!
  15. #15
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Still made it a tiiiiiiny bit slower, certainly no huge leap in performance anyway
  16. #16
    vs calais eco
    Sep 2006
    Disney land!
  17. #17
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    vp memcal in vn is no good like greenfoam said totally different spark map and ve table fuel economy goes out the window as well.
  1. How much faster is VS?
    By mischf in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2010, 08:41 PM
  2. good days and average days
    By Sabby in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-04-2007, 09:59 PM
  3. Faster Car Opinions
    By Alex_Vl_com in forum General
    Last Post: 01-10-2006, 02:18 PM
  4. wats faster
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2005, 10:57 AM
  5. Faster Acceleration
    By vl berlina in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-01-2004, 12:01 AM
