Results 1 to 10 of 10
Thread: vn v8 help
    vt equipe, vt exec, 97 wrx LE
    Sep 2008
    adelaide
    Thumbs down vn v8 help
    hey all just bought a vn v8 for 700
    its on lpg but the fuel pump is not wired in wich leads me too beleive that its stuffed and if connected it will short out the relay stalling the engine etc but back to the point, i know it has 2 pumps one internal one external.
    can i do away with the two pumps and just install one pump like say a walbro gss 341/342 rated at 255l/h or 500hp as it is heaps cheaper its 150 for the walbro or 79 for inernal and 178 for external or other way around.
    also what mods are needed for a t400 to go in the vn v8 is it straight bolt up but exchange the t400 yolk i found a t400 for 400 rather than a t700 for 1000
    has any one done any of theese mods please help
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I thought all the auto vn/p 8 had a t400. I havnt seen the duel pump setup yet but worst case, you could just buy a regular intank fuel pump setup from a wreckers and buy a new pump to go on it for $50-$100 and it will all be sweet.
    Reaper
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    The internal pump is a feeder/sender pump which feeds to the external pump which does all the hard work.
    ========My Statesman 20's Mafless and 3.9's========
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    VN/VP Auto's are T700's. Also, there is only one internal fuel pump, no external.
    car
    Jul 2006
    greensy, melb
    the t400 is the 3 speed in the earlier commy's, vn/p's have the hydrolic t700 which imo ****s all over the vr onwards t700 as theirs is electronic which = gayness
    "A life lived in fear is a life half lived"
    Jun 2005
    Quote Originally Posted by Mack View Post
    i thought v8s had two pumps? id say the pump is disconnected to stop you from putting fuel in because its probably been tuned for lpg?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by stocky View Post
    Some early VN's had 2 pumps. You should be able to convert it to a later single pump setup quite easily.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    the single pump out of a vn-vp or s v6 works, to my knowledge every vn had the twin pump setup which is the best, no fuel surges.
    th400 is a stronger box but lacks the extra highway gear of the th700, not hard to swap over same as the fuel pump, dont go overboard for now id suggest fixing whats wrong with the car as it is.
    Sep 2008
    adelaide
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    for what you payed you had to expect to have to fix some things? Just bite the bullet and do it right. you will be rewarded by reliability and more money at resale time because of the receipts for work done or parts bought etc.
