Results 1 to 7 of 7
Thread: clutch issues
    89 vn calais
    Oct 2005
    aldinga beach
    Default clutch issues
    hi all. i just bought a vn 5 speed executive.. if you remember it was on ebay in sa for 650.. its cream...
    anyway i have a problem ..
    you have to push the clutch almost too the floor to be able to get it into first... and if you try reverse it just grinds... the clutch does not slip at all as i have given it some real hell just to check...
    can the cable be adjusted (if so how)
    or could it be a problem with this plastic bearing im reading about
    (i searched for 2 hours to find an answer before posting)
    any help would be great as this is an awesome car.. totally standard with only 165,xxx on the clock..
    cheers guys
    dave
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Sounds like the clutch cable needs to be tightened a bit. Jack the front of the car up, stick it on stands, and take a look at the driver's side of the gearbox. Should be a black plastic cover somewhere down the bottom - unclip it and slide it back. Underneath you'll find a black dick that the clutch cable is fed through. You can screw it back and forth to adjust the position of the clutch fork at full release. If you can't tighten it up any more, then the clutch fork ball pivot stud needs adjustment inside the bellhousing. and that's a transmission off job.
    As for reverse - try shifting into 5th, then finding reverse. Reverse doesn't have synchros, so you have to use the 5th synchros to align the layshaft with your reverse gear.
    The 1972 HQ Kingswood
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    From experience it would be one of these, most probably:
    -stretched or poorly adjusted cable
    -collapsed thrust bearing
    -incorrect pivot ball height
    Everyone that i know with a v6 T5 has to select another gear before selecting reverse VERY CAREFULLY, to avoid crunching. Personally i: clutch, lightly load reverse gate, off clutch and back on, then select reverse slowly. Like a double clutch action.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    Morton's Avatar
    May 2006
    Hey REV-231, try selecting 5th gear before reverse next time Works a treat on my T5, and you can do it as fast as you like.
    GTP 85's Avatar
    Aug 2006
    thats what i was told 1st.. doesnt work for mine. how retarded is reverse gear? sh1ts me sometimes
    Morton's Avatar
    May 2006
    lol, that's pretty gay then Commodores are the only cars I've driven sofar that don't have reverse synchros. It's pretty oldschool lol
    Jul 2008
    Reverse grinding is a healthy commodore thing. Mine grinds in reverse nearly every time, unless i wait with the clutch in before selecting it.
  1. vu ute clutch
    By ripper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2009, 10:26 PM
  2. 5.7 ltr Vy Clutch
    By Purplecrewy in forum LSx Development and Modification
    Last Post: 02-05-2008, 10:10 PM
  3. Clutch in VY
    By skins in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-03-2007, 02:59 PM
  4. GRRRR... New Thunder SS, Clutch / Gearbox Issues
    By nickbalcombe99 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-10-2006, 09:34 PM
  5. Vs Clutch Issues
    By 10wvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2005, 03:03 PM
