I have a COmmodore VP 1992 with the origiinal radio. How do i remove it?
The 1972 HQ Kingswood
Take a big arsed hammer and screw driver to the radio/console. Works a treat. Or alternativly, park it in a seedy area unlocked and wait for someone to steal it. But you'r car may go missing aswell, either way problem solved :P
hey xXdanXx i have done the same thing but what i did was i took the top of the transmisson cover off its just a clip on so you can pull it off and then you should see three screws on the lower part of the front panel which encases the radio and aircon take all of them out and it should just pull out now the confusing part now you have to take out all the other screws to the surrounding panel of the front panel some will be behind the glove box lid and the retaining pins under the steering then once you have taken that out and then the screws to the radio are visible and the rest should be self explanitory good luck with it
