Results 1 to 13 of 13
Thread: Creaky rear springs
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Default Creaky rear springs
    Anyone able to shed some light on what could be causing this? It's pretty annoying. They're King superlows with koni shocks.
    WTB: mulberry VN interior parts
    VN Calais 5L
    Dec 2006
    springs themselves or shocks? if its springs it could be as simple as the rubber boots arent sitting over the springs properly.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Quote Originally Posted by VNexecutive View Post
    that would be my guess, mine were fine... then started creeking a bit so i had a look and the rubber was dead... so maybe worth a look?
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    comes with wear, my old commodore had the same problem, if you take the spring out and have a look at the angle of where the spring sits yours is most likely on a wonky angle cauing the spring to make boujncing/spring tension noise...
    Dont know what causes it i sold the piece of crap for 1000 bucks and passed it onto the next owner : p
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I think it's springs, seems to creak with bounce and cornering weight transfer. I'll have a look at the rubber boots, hopefully I won't need new ones, the car has been cut off from funding
    304 Calais
    Aug 2007
    Up your mum
    now that im in a better state of mind and read the op properly, a creak when going over corners could be the panhard rod body mount tearing off, my vp had that for weeks until i got it welded up by a boilermaker and the creaking stopped.
    The noise i was reffering to before is more of a springy, bouncy noise.
    something to check out.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Nope mounting looks fine.. it's all still firmly attached as far as I can tell
    And just out of spite, it won't creak while I bounce the car as hard as I can.. I'm only light haha so I've no idea where it's coming from.
    VN Calais 5L
    Dec 2006
    one of my springs used to creak in my ss, boots looked fine but were worn through the bottom. quite an annoying noise.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The 89 Green sedan had this horrible squeak and it turned out to be a rouge exhaust bracket that had been stuffed on top of the muffler. I damn near stripped the car - I mean back seat out - almost everything. Only when it went on the hoist did we see it. Yanked it out as it was not bolted on - it should have fallen out but no it sat there and squeaked and sque.......... @%$#*&% thing!!!
    and 3 Dangerous non ABS VN's
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    my mums vn had an annoying squeak at the rear....turned out it was the lower control are bushing was totally flogged and resting on the bolt sleeve....was quite dangerous
    so to be sure check all the bushes at the rear
    Vp series 2
    Jun 2008
    try lubing the spring mounts.
    Ky is something that most of us have laying around and does not affect rubber. makes a good substitue for rubber grease.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    lol! KY
    couple of suggestions there, thanks guys, next time the car's up I'll have a look!
  1. Removing rear VX springs
    By DANNY8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2008, 07:31 PM
  2. Creaky steering
    By wetwork65 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-04-2008, 08:57 PM
  3. Rear springs
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2008, 09:56 PM
  4. Wtb Vs Non Irs Rear Springs
    By biganf in forum Swap / Wanted to Buy / Trade
    Last Post: 10-01-2007, 06:04 AM
  5. rear springs for VS IRS
    By demenace in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2006, 03:16 PM
