Results 1 to 17 of 17
Thread: battery in back of wagon
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Default battery in back of wagon
    I need to move the battery out of the engine bay of my vp wagon, does anyone have any pictures of a battery in the boot of a wagon? and know what the legal requirements are? (ie sealed box) or any info i might need to do this.
    Cheers Matt
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    from memory, in VIC you need to have either a sealed battery type battery, or you need a sealed box with a vent to outside the vehicle (i.e. underneath the box etc)
    also needs to be secured - I don't know whether being in a battery box is considered 'secure' or not though.
    VP Exec
    Jun 2005
    That sounds pretty much it and I think that it will apply in QLD too as the National Code of Practice for Light Vehicle Construction and Modification (NCOP) should apply. I am pretty sure that some sort of clamp as well as the box will be necessary.
    Here: http://www.infrastructure.gov.au/roa...s_3Feb2006.pdf
    2.11, page 7 National Code of Practice for Light Vehicle Construction and Modification (NCOP)
    I don't know whether or not you have seen this but it looks useful:
    Browser Warning
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    thanks for the links,
    i think i will make a box out of stainless. Unsure where to run the wires back i can't find anywhere to run the wires through the firewall. i was thinking of running them back beside the fuel lines and coming up under the box.
    Matt
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by Matt_vp View Post
    Matt
    might be better making it out of alloy to reduce some chance of arcing
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Quote Originally Posted by hartsc View Post
    afaik alloy still conducts electricity..
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    do what the ute guys do and run the wires under the car to dummy terminals in the bay so all ur original stuff hooks to the bay dummy terminals. There was a how to guide in street commo's mag a couple of years back. looked allot easier than it sounds
    ========My Statesman 20's Mafless and 3.9's========
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Quote Originally Posted by ucwepn View Post
    yeah i was going to make some bolton type terminals for the engine bay then follow the fuel rails down to the back of the car, i made a box out of stainless last night, it looks a bit bulky but it will work, i will run the wires and bolt the box in 2nite. and try and get some pics. also looking at moving the fuse box aswell, probly just move it down to where the battery is and i should still have enough room for some pipework
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    thats why I said reduce.
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    i got the battery mounted in the back and all the wiring run, i used 3mm rubber under the battery and have a bit that folds over the top of the battery and terminals to help protect from anything arcing out i will try and get some pics up 2morrow
    Matt
    commsirac is offline Banned
    vx
    Aug 2007
    You only need to run one wire, use the body of the car for the return......you've already paid for it and it will work better than any cable you can reasonably put under there.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Quote Originally Posted by VN_Luke View Post
    anyone know are sealed batteries heaps expensive?
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    i think they are quite expensive, i will b going down to battery world next week sometime to find out.
    Matt
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Quote Originally Posted by commsirac View Post
    i ran 2 wires down along beside the fuel lines, the cable is 12mm.
  15. #15
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Matt
    Yea thats the ticket, in NZ the sealed type batterys (exide orbital with side and top posts) is around $280 but some places are as cheap as $220. I have one in my car(only cos my ol van didn't have tie downs or anything to tie down so when i sold that orbital went into the commy and kept it ever since.
  16. #16
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    12mm for the core or 12mm including the plastic coating?
  17. #17
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Quote Originally Posted by hakhawk View Post
    12mm for the core.
    Matt
  1. wagon back seats
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2009, 07:01 PM
  2. 2nd battery in VZ acclaim wagon
    By bajdas in forum Electrical Wiring / Questions
    Last Post: 27-08-2009, 12:06 AM
  3. Help! Where to install battery in VS Wagon
    By nuga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2007, 12:38 PM
  4. Wagon cover for back.
    By Kiwicommodore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2006, 10:26 PM
  5. VX Series 2 Wagon Cat back
    By VXWAGMAN in forum Parts And Other Items For Sale
    Last Post: 29-09-2005, 01:07 PM
