Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VN - VP Holden Commodore (1988 - 1993)
VN - VP Holden Commodore (1988 - 1993) Talk about anything relating to the VN - VP Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 30-09-2008, 10:42 AM
Nevyn's Avatar
Ride: VN Sedan
Trade Rating: (0)
Nevyn Berlina
Default VN not changing gears smoothly
I put a new set of injectors in the V6 on the weekend and ever since the car will rev heaps (up to 3K) before changing into the next gear. Its done it before, but suddenly stopped and started to change fine but I could never fine out what caused it. Now its doing it again I want to find out what it could be if there is a problem.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 30-09-2008, 12:21 PM
Ride: VP Exec
Trade Rating: (0)
Cheap6 MalooCheap6 Maloo
If it was only a one off thing each time and the battery has been disconnected, it sounds like the ECM relearning the IAC motor position. If it's ongoing, more like a manifold vacuum leak. Perhaps from 1+ of the seals between the injectors and the manifold. (Also assuming that the injectors are the same as those being replaced).
  #3
Old 30-09-2008, 12:39 PM
jas98's Avatar
Ride: vs commodore V6 series 2
Trade Rating: (0)
jas98 Berlina
try adjusting the kick down cable
  #4
Old 30-09-2008, 12:41 PM
PaRaDoX's Avatar
i want a VTEC ECU
Ride: mk3 Toyota Supra i6t, Mitshibishi Magna Wagon v6
Trade Rating: (0)
PaRaDoX MonaroPaRaDoX Monaro
hehe nevyn, check your kick down cable mate! & reset it!
i gaurentee you knocked it while fitting the injectors!
__________________
Rice rice baby...
http://forums.justcommodores.com.au/...rga-supra.html
  #5
Old 30-09-2008, 12:43 PM
Nevyn's Avatar
Ride: VN Sedan
Trade Rating: (0)
Nevyn Berlina
I'm sure I have a manifold leak anyway and plan on changing the gasket....the injectors are the same as the one taken out. It could be the ECU, as I had the battery disconnected while changing the injectors. The last time this was happening was when I changed engines. I also have a new throttle body to put on, but am waiting to get a new IAC & TPS before fitting it.
  #6
Old 30-09-2008, 01:05 PM
Nevyn's Avatar
Ride: VN Sedan
Trade Rating: (0)
Nevyn Berlina
I may have, but I took the bracket on the throttle elbow that holds the cable off so it wouldn't be in the way.....I'll see how it is tonight after a bit more driving.
  #7
Old 30-09-2008, 09:40 PM
Nevyn's Avatar
Ride: VN Sedan
Trade Rating: (0)
Nevyn Berlina
put a greenfoam memcal in this arvo and now changing gears fine.....so kick back cable must have been fine.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
not changing gears properly showtime VR - VS Holden Commodore (1993 - 1997) 3 16-02-2007 12:28 PM
changing gears in an auto [MR SS] VN - VP Holden Commodore (1988 - 1993) 12 02-06-2006 07:38 PM
changing gears in auto stocky VN - VP Holden Commodore (1988 - 1993) 7 19-03-2006 08:18 PM
ChAnGiNg GeArS In AuTo vy_pete05 VT - VX Holden Commodore (1997 - 2002) 34 23-10-2005 02:05 PM
Stalling when changing gears fitzy2005 VR - VS Holden Commodore (1993 - 1997) 20 10-10-2005 05:46 PM
Online Advertising | Credit Cards | Homeowner Loans | Wohnung Berlin | British Article Directory | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
