Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: ive had it with my vp :bang:
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    Angry ive had it with my vp :bang:
    my car is about 2 seconds from getting crushed i just replaced the cas for the 3rd time and it chewed it up and spat it out again i cant see any of the disruptor teeth on the balancer out of alignment any idea's why its doing this ????????????????????????????????????
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    put a new balancer and matching VP series 2 CAS on... had the same problem with my old VP
    Vp series 2
    Jun 2008
    not all series 2 vps have the badge on them.
    My late 92 vp has the earlier metal bracket cas and the later style balancer.
    Try to move the balancer when you fit it to chech for bearing play.
    Bearing play = sell asap
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Baring play what do you mean by that? are you talking about end float in the crank?
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Jun 2008
    golden beach
    well i checked for bearing play first and that's fine and as far as the series 2 its a series 1 metal bracket and white sensor i didn't think that the sensor plug end fit for both and i didn't think the ecu was the same ?? just cant work it out i am just about to have a vp bonfire
    Jun 2008
    golden beach
    Default it wouldant want to anyway
    it wouldant want to have much play i just rebuilt the motor board out ect
    Jun 2008
    golden beach
    and hay pub nice Calais funny relay i own and drive a fairlane but theres no way in hell the old girl would even come close to the vp
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    when you got your cas were you asked for a engine number, there are 2 or 3 different air gaps on the sensors
    Jun 2008
    golden beach
    Default no i wasant asked
    no i wasn't asked i just asked for a series 1 cas but then again we are talking about autobahn i would like to know more please continue i dont want to have to keep throwing 44$ away
    Jun 2008
    golden beach
    Default hay cool
    hay low vp i use to live in riverview i here redbank is finally sinking lol
    Jun 2008
    golden beach
    Default bugger!!!
    ithink i might just buy a horse at least then i can just shoot it
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    PM me your engine number and I can give an approx date when it was made.
    and 3 Dangerous non ABS VN's
    Jun 2008
    golden beach
    cant help you to night but will for sure get the number to you by 2 morow night thanks heaps for the help
  15. #15
    88GreenVN's Avatar
    Jun 2006
    Some info to start with:
    VP's engine numbers range from around VH1216562 (Aug 91) to VH1324077 (Jun 93)
    Frist VN with a VP motor was Nov 90. ( car serial No L474742)
  16. #16
    Jun 2008
    golden beach
    yep cool saved that to my desk top
    i dont know what id do without you guys helping me
    oh yes i do id burn the thing lol oh well heres hopping that i can breath life into her again
  17. #17
    Boonz's Avatar
    Jul 2005
    if you use a late 93 year model VP sensor AND late 93 model balancer you wont have a problem cos they are a matched pair....then you will eliminate the chance of breaking it all together......
  18. #18
    Jun 2008
    golden beach
    Default well itsa series1
    i know for sure its a series 1 engine thanks to 88GreenVN helping me thanks i guess i just have a bent tooth in there that i missed
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
  19. #19
    VN Sedan
    Jan 2007
    Latrobe Valley
    Hope u get it all sorted...might see about making it up to bainsdale and see ya do ya thing.
    with the cas and balancer, can u have the same problem with the Series 1 VN? I'm looking at replacing the cas hoping it will smooth out some vibrations and a mates early Calais needs a cas as well...hate to run into the same problems u are having
  20. #20
    Jun 2006
    I had to replace CAS & I supplied the part which was correct one and when mechanic put on he did not adjust it correctly and chewed it up as I turned over the engine...
    expensive lesson that one...
    take your car to an auto electrician who knows what their doing and get them to do...
    Apparently the CAS can be a ****ing pain to replace if you dont know what your doing.
    cost me $140 to get another mechanic to do with 12 months warranty..
    Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden
  21. #21
    VN Sedan
    Jan 2007
    Latrobe Valley
    Quote Originally Posted by aussieghostrider View Post
    thanks, will keep all that in mind.
  22. #22
    Jun 2008
    golden beach
    well i got my new cas today i have a mechanic dropping buy asap to fit it (for free) well not relay but hay who would say no to a 6 pack of jim beam so lets see how i go if its all good i have a mini spool to put in and i suppose i better pull my finger out and send my chip of to green foam
  23. #23
    Jun 2008
    golden beach
    Default vn 1 and 2
    Quote Originally Posted by Nevyn View Post
    ok i up loaded my cas install instructions in my albums and if you want a cas fast and your in the lower states this is where i got mine
    http://stores.ebay.com.au/Aussie-Parts-Diy
  24. #24
    Jun 2008
    golden beach
    Default found the problem
    ok i found the issue it turns out my balancer has 1 of the disruptor teeth just out of whack it only is just enough to catch the sensor but until you look really hard you cant see the difference i spose my vp would ave to be different and destroy the sensor instead of it just being faulty so the lesson here is that if the cas gets destroyed and that's why you are replacing it take special notice of the teeth that they are all aligned PERFECTLY
  25. #25
    VN Sedan
    Jan 2007
    Latrobe Valley
    Quote Originally Posted by rob drag vp View Post
    arn't u suppose to use a feeler gauge (0.5mm I think) between each tooth and the sensor?
  1. bang
    By vr-man in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2008, 10:49 PM
  2. :bang:
    By BURK_POP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-03-2007, 08:50 PM
  3. ARRRRRH! HELP loud bang bang bang noise
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 10:58 PM
  4. re:big bang
    By VK1981 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-02-2006, 08:42 PM
  5. Bang :(
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2006, 06:14 PM
