Whats the best way to remove the exterior door trims off a VN?
I am planning to replace my black executive trim with a s pack trim.
How should I go about attaching the replacement trim to the car (Loctite perhaps)? Any feedback would be appreciated.
Youll need.....
A few lengths of fishing line.
A can of prepsol or similar to clean the areas.
A few rags.
Run the fishing line under the trim to slice through the glue/tape then use prepsol or thiners to remove the leftover glue and to clean the area.
Finally a coat of polish where you have applied the prepsol to seal the paint.
Use thin (1.5mm max) 3M double sided exterior tape to apply the new trims.![]()
here you are dude, someone did a write-up on it here
DIY: Removing those pesky door moulds
opinions are like a**holes, we all have one
