Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Speedometer not working
    Hardstylin is offline Banned
    VP Calais
    Aug 2008
    Melbourne, Victoria
    Default Speedometer not working
    Hello,
    The speedometer on the dash cluster in my VP Calais was working on and off, I purchased another dash cluster for $120, same issue.
    What would be the quickest yet most effective way to fix this?
    Cheers,
    Chris
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    not just a sticky gauge, have you tried giving it a bit of a whallop
    The Black Beauty
    VP Calais
    Aug 2008
    Melbourne, Victoria
    Quote Originally Posted by pow3rslave View Post
    it's the speed sensor under the car, think it's on the gearbox.
    Okay, would I need to replace this or is this something I can fix myself?
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    i think replacing is the go, but i got mine done by an auto sparky, all up i think ~$300, steep but i didn't have time to try it myself at the time, that was with a new part. didn't want to get a 2nd hand and have it die
    VP Calais
    Aug 2008
    Melbourne, Victoria
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    The speed sensor on the V6 Automatic is on the passenger side towards the back, near the extension housing (where the tailshaft goes). You see the wiring once you stick your head under there.
    Illegitimi Non Carborundum
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Just replaced the sensor on the 89 green sedan - $20 and alls good
    and 3 Dangerous non ABS VN's
    VP Calais
    Aug 2008
    Melbourne, Victoria
    Quote Originally Posted by 88GreenVN View Post
    Yeah?
    Mate, that's a relief. Where did you buy the sensor from?
    Chris
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Hardstylin View Post
    Yeah?
    Chris
    The wreckers. took em 15 mins on the hoist.
    skyper is offline SKYPER
    SV6
    Aug 2008
    LISMORE NSW
    Default speedo
    speedo needle works but the miles won't clock up, neither does the trip meter, is it electrical or is it cogs,any ideas
    SV6
    Aug 2008
    LISMORE NSW
    SV6
    Aug 2008
    LISMORE NSW
    Default speedo
    the needle works but it won't clock up klm's ,is it electrical or cogs,trip meter dosn't work either
    VP Calais
    Aug 2008
    Melbourne, Victoria
    Can someone please take a picture of the speed sensor and post it up?
    It would be greatly appreciated, thank you.
  15. #15
    car
    Jul 2006
    greensy, melb
    Quote Originally Posted by skyper View Post
    Hello,
    Cheers,
    Chris
    i believe this would be for both of you, the speedo sensor just unscrews by hand and if it is what the problem is then best option would be get one from the wreckers for about $20 otherwise holden charge about $240 for one.
    the 3 wires that go into it get very brittle and hard over the years so it's quite possible that they may have broken off so which you would have to get a new sensor.
    Attached Thumbnails Attached Thumbnails Speedometer not working-rimg0695.jpg   Speedometer not working-rimg0698.jpg
    "A life lived in fear is a life half lived"
  16. #16
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    hehe yeah dont try fixing it if its shafted, too much of a **** around, remember manual and auto ones are the same
  17. #17
    VP Calais
    Aug 2008
    Melbourne, Victoria
    Quote Originally Posted by kniever View Post
    Cheers mate, I went into Holden and they said they don't sell them anymore and my best bet is the wreckers.
  18. #18
    92 Vp Calais 5.0l
    Nov 2008
    went underneath my car to c if i could take it off. no go? and its covered in fluid too..mayb leak sumwhere. Does it unplug buy the wires first..coz if u unscrew it first itll twist the wires. On v8 vps is it on the same side?Passenger side hey? thnx help would b appreciated
  19. #19
    VP Exec
    Jun 2005
  20. #20
    VP Calais
    Aug 2008
    Melbourne, Victoria
    Okay, so went to the wreckers, they wouldn't take one off for me so I decided to try it myself, unscrewed one off a VN, got home, took mine off and realized the pin in the one I got from the wreckers was broken, looks like I'll be going back to get another.
  21. #21
    HSV VP Calais
    Jun 2009
    Exclamation HSV VP CALAIS 1992 MODEL. Speedo does not work
    I just bought a HSV CALAIS V8, the speedo does not work, since this does not work neither will the trip computer, cruise control & distance left till empty. Please how do I rectify this problem, Car is located in Bass Hill area.
    Thanks...
  22. #22
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by robsul66 View Post
    Thanks...
    Check the speed sensor on the gearbox.
  23. #23
    Greedy is offline Greedy
    VN Areo
    Jun 2009
    Narangba
    Wink Re: speedo working but k's not
    I had the same problem speedo works but no k's i checked the servo pick up in the gear box its fine. Next thing to do was check the dash. Pulled the cluster out and apart and found the gears in the k's where stripped!. Brought a secound hand one and it lasted long enought to get through road worthy and the same problem again stripped gears. I ended up getting one from ebay for i think $150 and came with stylish hsv white faced gauges.
    In the vn its easy to take out sorry to say $300 is alot of money. All up it took me 20 mins max to put in. Start with the two bottom screws under the lights and window wiper switches. then their are two screws above the gauges. Pull the dash out then their will be 5 wire connectors just pull them off you cant put the connectors back in wronge as they have location pins so you cant stuff them up. On the cluster look for two screws on each side off the cluster and remove them. Now grab the cluster and pull towards you with alittle force and it should unclip.
    To check the gears in the cluster remove all the lights then undo all screws plus bolts. And then unclip the membrain going into the fuel gauge. The two parts to the cluster will just fall apart on the side of the k's cluster is a small motor held in by three screws remove them and you can now see the gears check to see if they are stripped if they are then thats your problem.
  24. #24
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Greedy View Post
    The L3 dash has a digital trip meter and DTE. If the signal is missing from the speed sensor the speedo will fail.
    Also I'd be checking the PCB where it plugs into the trip computer - it may be broken.
  25. #25
    VN Areo
    Jun 2009
    Narangba
    lol 88 GREEN VN your right sorry didnt think off that. With that note you can use a muilti meter and see if there is any voltage while driving.
  1. speedometer
    By macatac in forum Electrical Wiring / Questions
    Last Post: 21-08-2008, 09:06 AM
  2. speedometer sticking
    By hcvr1994 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2007, 09:27 PM
  3. VN Speedometer
    By snoogy_beef in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2006, 01:06 AM
  4. Speedometer Not Working
    By Aussie_Watto in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-08-2005, 06:32 PM
  5. VR speed alert and speedometer not working
    By johnnyk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2005, 03:31 AM
