Results 1 to 5 of 5
Thread: speed sensor?
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    Default speed sensor?
    ive finally got my v6 gemi goin. so excited, til i took it for a spin and it cuts out when i guess im doin bout 50km/h or so. its such a tight squeeze in the tunnel that the sensor sits hard up against the tunnel. so i assume that its damaged...
    im sure ive read that this symptom is caused be a faulty sensor. can anyone verify?
    cheers,
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    when my sensor was bung, mine cut out. it was grouse fun too, hard lock turning left car cut out, steering locking pin engaged, mounted kerb
    VH stock
    Nov 2011
    Dennington
    Hi . . I've just completed a V6 manual conversion of VN into another car and its doing similar to what is doing. It will only get to about 35/40km/h and cuts out, but comes good again . .
    The engine light stay's on but goes from "bright" to "dim" when the engine is started but it just comes up with a code 12
    Was hoping you could tell me what the problem ended up being with your ride??
    1991 VP commodore series 1
    Dec 2011
    perth
    hi, where is the speed sensor located? new to buick also, i was told i can wire my rev limiter straight to that but not sure where to look..
    few commodores
    Feb 2011
    victoria
    near the shovel at the back of the extension housing
  1. speed sensor
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-02-2007, 12:37 PM
  2. HELP: No Speed sensor, what happens?
    By simc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2005, 10:51 AM
  3. Speed Sensor
    By infernojs in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-05-2005, 10:35 PM
  4. speed sensor
    By danwalton86VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2004, 07:41 PM
  5. Speed Sensor
    By vk_calais in forum Electrical Wiring / Questions
    Last Post: 07-03-2004, 09:24 PM
