Results 1 to 6 of 6
Thread: v8 issues
    vt equipe, vt exec, 97 wrx LE
    Sep 2008
    adelaide
    Default v8 issues
    hey,
    got a vn v8 having issues,
    trans is ****ed and she is lacking power is this because the trans is ****ed and has tourque converter problems or cause its on gas. should i run it on petrol/gas straight gas or straight fuel.
    also it takes forever to start on gas.
    and the battery went flat after running the car at a stand still for around half hour or so battery is at 13.6 volts is it the alt thats ****ed or the battery
    and how do i remove the crash pad(dash) oput of the vn i cant find any info has some one got a link cheers
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by capitalgainz View Post
    If the battery has 13+ volts accross it while the car is running then I'd think the alternator is ok. Disconnect the battery and make sure it is 12 volts. Also check that the fluid is just over the plates in the inpection tubes. If it is lower than 11 volts after an hour or so then it isn't holding charge and you will probably need a new battery.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Sep 2008
    adelaide
    Reaper's Avatar
    Aug 2004
    I'd fix the auto, **** off the gas and get it running right on petrol.
    Reaper
    Reapers Black VP SS
    Sep 2008
    adelaide
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    your motors hard to start because the converters not been tuned properly, had to fix up a f350 (carby) over the weekend which had the same problem...
    13.6 is normal, try turning all your lights (highbeam, radio, etc on then check the voltage.... otherwise thats normal.
    Engine performance can be governed by the automatic transmission, in any v6 or v8 auto the car should glide with minimal pedal travel, first thing to check is fluid level and condition. If there both fine then your most likely up for a rebuild.
    What exactly is the auto doing, slipping, being sluggish, locking late (converter) ????
  1. VZ Issues
    By tigerpm7 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-05-2008, 06:40 PM
  2. T5 issues
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2008, 10:01 AM
  3. LH LPG Issues
    By Rzeractor in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-04-2007, 11:56 AM
  4. Known Gen III Issues
    By Fagio in forum General
    Last Post: 11-01-2006, 02:18 AM
  5. CD issues
    By rgfoster67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2005, 02:32 PM
