Results 1 to 3 of 3
Thread: vp Interior light trouble
    vp commodore wagon
    Oct 2008
    Default vp Interior light trouble
    Hi some weeks ago i replaced the rear tailgate struts the rear wagon light came on but the Interior light went out and won't work any more the key light on the steering column works if i push the dome button but not the dome light. I have checked the piller switches I have cleaned them and tested them off the car the fuse has power but no power to the dome light.
    Can any help
    sean
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    if the fuse was too high an ampage, you could have burned out burned some wiring
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    I had the same problem and couldn't fix it, so for now i just took the centre light out, and just use the map lights.
    Mine also flickered on and off while driving, even when the switch was of. Might be a dud switch.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
  1. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  2. vn interior trouble
    By vn_lexcen_s2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2006, 12:11 PM
  3. engine trouble light code 13
    By vr_calais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2006, 08:21 PM
  4. trouble with indicator & interior light problems
    By slwbt1 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-10-2005, 08:35 PM
  5. VP instrument light trouble
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2004, 08:01 PM
