Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: VR level 2 dash into VP level 1???
    VP Executive S2, VL 5sp Berlina Wagon
    May 2008
    Down South, Adelaide
    Default VR level 2 dash into VP level 1???
    Hey guys i currently have a VP level 1 dash in my vp and am wanting to upgrade to a level 2 dash with a tacho, i have a vr level 2 dash and im wondering if its possible to pull the clusters out of the vr dash and put them into my level 1 dash.
    question 1 - will the tacho work even though my vp dash is level 1???
    question 2 - will the instrument clusters fit straight into my vp dash???
    Also what is required to put cruise control into a vp with level 1 dash, i can easily get the cruise control switches from a wreckers but wondering if more wiring needs to be done or anything else.
    Thanks, Anthony
    LightningVP is offline Donating Member
    None
    Sep 2008
    From what I know, VR/VS cluster is the same as the VN/VP ones...so you should be able to put it in...
    As for it wiring up, yes it will.
    Vp series 2
    Jun 2008
    Just check the numder one the sockets at the back to make sure they are the same.
    If they are not the same then you carefully remove the green circuit film and swap them over, then you just need to swap over the front cover as the dash warning lights may be different.
    Yes this works i have a vs cluster with vn front taco and corcuit in my vp.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Is it just the VR/VS L3 clusters that make smoke when put into a VN/VP?
    Are L2 cluster good to swap?
    and 3 Dangerous non ABS VN's
    May 2008
    nop the L2 smoked lol, burnt out 2 circuits, probably should've done my research before just plugging it in.
    Still looking for a defiant answer
    May 2008
    anyone sure if the vr level 2 cluster can be placed into a vp level 1 cluster and have the working tacho?
    Vp series 2
    Jun 2008
    dude change the green circuit board and the clear font cover and it WILL work fine.
    I HAVE a VS cluster in me VP
    May 2008
    Quote Originally Posted by centy View Post
    it wont work, the vr dash fits in perfectly, except it smokes, the wiring on the vr is different, even if i change the green circuit board its still going to smoke due to it having the wiring differently. Someone correct me if im wrong but i tried to install the vr dash straight in, fitted perfectly and then reconnected the battery and it started to smoke, burnt out two of the circuit lines.
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    the vr/vs dash cluster WILL NOT work in a vn/vp......
    i have tried this, and it burnt out the wires in my mates vp sedan...
    it cost me a new dash harness in the process.......
    the level 2 dashs cost around 50 bucks at the wreckers... just finding one in good nick is ur only problem..
    May 2008
    yeah i have worked that out by experience, the question im asking is, will i be able to take the instrument clusters out of the vr level 2 dash, and put the clusters into my vp level 1 dash and have them all working, including tacho. if u get what i mean, because i prefer the vr ones over the vp ones. im just asking if it'll work, otherwise ill got get a vn or vp level 2 dash and put the vr clusters into that as i believe that they are all interchangeable just unsure if they are between different level dashes. thanks aswell for your clear answer NV_90VN
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Ive got a VR lvl 2 one in mine, either that or the faces are from a VR but it dose look like the circuit on the back has been changed.
    I know if you do that having the clusters from the same car it works, and since people say its all the same cept the circuit this seems like the way to go.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    May 2008
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    np, if worst comes to worst just buy a VN/VP lv2 and change the faces.
    I got mine because i liked the VR one better off ebay but i went to this guys house to see if it worked in a VN as he claimed first
    The Daily VN T5V6
    355 VN GRP A REP
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    In response to before, yes, if you take the individual gauges out. Not sure how levels 1's swap with level 2's, but speedo etc are definaintly interchangeable. AS already said, don't put the whole cluster in.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
  15. #15
    May 2008
    thanks for the help stealthy and mischa again, questions answered now, off to wreckers to get a vn level 2 and get vr gauges in in.
  16. #16
    Vp series 2
    Jun 2008
    ok so don't listen to the guy who made the same mistakes that you have and found out how to get around them.
    the ONLY difference you need to worry about is the green circuit on the back is different and the little ligth up bits in the front.
    The speedo and other cluster bits ARE the same in vn, vp and vs.
    The easy was it to take the grren board of your level 1 dash and fit it to the vr dash.
    YES you have to put a few extra holes in it and cover a couple but they are all marked allready.
    SAVE your self the money, i went through 3 dashes to discover all this.
    Or go spend more cash to buy a vn one ready to go.
    PS most vn dashes don't have the press key light.
  17. #17
    STEALTHY™'s Avatar
    Jan 2005
    Yes, personally i would've just bought a $20 dash. But its handy to know if you need a dash and thats all you have to work with.
    cheers sexy
  18. #18
    May 2008
    Sorry i didnt know u meant take the green circuit bored of my vp dash and put it onto the vr dash, i thought u meant the other way around. Thanks four that ill be having a look at that today and trying it.
  19. #19
    May 2008
    All fixed now, got a level 2 vp dash, swapped the vr level 2 dash for it, put my speedo and odometer in and all away now
  20. #20
    88GreenVN's Avatar
    Jun 2006
    Soooo good to say good by to L1 dash.
    Next will be the L3 conversion
  21. #21
    May 2008
    Haha your too right, soo it will b time, couple of other things to sort out first then time for L3 conversion, will some help.
  22. #22
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by Abrowne70 View Post
    You can fit the Level 3 dash withoput any modification, although you wont have any of the trips at the bottom working (and no odometre), but speedo/tacho and fuel/temp will all work
    cheers sexy
  23. #23
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by STEALTHY™ View Post
    owww what! now you tell me! i didnt want a lv3 just cause i hate mucking around with wiring but i do like the look of them and now you say it still would of worked!!! (well as much as i needed)
    The Daily VN T5V6
    355 VN GRP A REP
  24. #24
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by mischa View Post
    I've mentioned it in a few posts. Keep in mind no odometre means its technically a defect, not that i car either way
    cheers sexy
  25. #25
    None
    Sep 2008
    Don't want to be a thread digger, but I just did this with mine, put a VS 2 into my VP 1, Changed over the front panels, plastic board on back, and the small circuit board inside....Even spent hours scratching away at the plastic to get the metal points where the new holes are....All works fine (now), except the tacho...I was told that it works fine, was taken out of a written off vehicle, and I trust the person that I got it off, but anyway, could there be a wiring problem in my car that is affecting the tacho not working, or could it be the tacho? and if so, how would I know without buying a new lvl 2 cluster?
  1. level 2 tacho into level 3 dash
    By andynogo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2008, 05:34 PM
  2. v6 level 3 dash into v8?
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2008, 01:02 PM
  3. How do I fit a Level 3 Dash into VP Level 2?
    By nsladden in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2007, 08:28 AM
  4. Level 1 dash cluster to level 3
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2006, 06:28 PM
  5. Vr level 2 dash
    By BrianT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2005, 09:38 PM
Tags for this Thread
