Results 1 to 2 of 2
Thread: inlet manifold leak V6 VP
    May 2008
    Default inlet manifold leak V6 VP
    went to check the bolts on the inlet manifold and the back ones were loose, tightened them up but took a look around and looks like old oil around the alternator and coated on passenger side of engine down to the oil pan. bolts on front of manifold were tight, car also has a rough idle that if you sit at the tail pipe, it kind of puffs every few sec (no smoke, just the sound). Should I just replace the inlet manifold gasket to be safe...I was thinking maybe a vacuum leak causing the idle to go off?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    yeh i would just to be on the safe side....the gasket kit only cost me 40 bucks plus the oil and coolant soo yeh not allot .....it did make a huge difference on my old VN. Not hard to do either
  1. Possible leak in the inlet manifold
    By neobristol in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-10-2008, 07:27 AM
  2. inlet manifold gasket leak?
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2008, 09:50 PM
  3. inlet manifold
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 09:52 PM
  4. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
  5. wtb: inlet manifold for vh
    By white vn ss in forum Swap / Wanted to Buy / Trade
    Last Post: 12-03-2006, 12:47 PM
