Results 1 to 12 of 12
Thread: Fuel pump dead, need help with lpg...
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Default Fuel pump dead, need help with lpg...
    OK, I know this club doesn't know much about or really like LPG but i thought its worth a shot because i need to get my car home, so here is the story.....
    My fuel pump died on me and it decides to do it when i get some work done to my car.......
    So at the moment my car is not sitting in my drive way like it should because i couldn't get it home...
    The problem is i couldn't even use gas because my car is set up to start on petrol and when i rev it a little, it changes to gas....
    So no start on petrol = no running gas for me...
    So i have a wire that is connected to 1 of my spark plug leads and that switch's it to gas when there is high current etc going through the spark plug lead, just wondering what the hell i would do with this wire so it will start on gas and not have to use petrol 1st....
    I know this probably wont make sense, and not many people know about gas but i thought i would ask so i can drive my car home and not get it towed....
    Thanks in advance, any help would be appreciated
    Jul 2008
    hmm you could try rolling it down a hill, that may fool it, In gear of course. But ive never heard of that before. If the tank lock off solanoid is opening, and the 2nd lock off solanoid before the conver is opening, All youd haft to do is rip the guts out of the Third lock off solanoid that is located on your converter ( black box looking mofo with 2 wires comeing off it )
    With mine its set up to give it a squirt of petrol when fireing up on gas, but after that its nothing but gas.
    Or my only other suggestion is to get some fuel or start ya bastard wd40 etc and squirt it down your throttle boddy, the car will fire up that way, and if you hold the pedal down it should rev to a point where your gas kicks in. good luck !
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    Quote Originally Posted by DavoVP View Post
    yeah thats how mine is set up, starts on petrol but i rev it a little and it changes to gas and is only gas....
    thats exactly what i was thinking, i guess its the only way, then drive it to the guy who usually fixes our lpg problems so he can change my switch so its either gas or petrol, none of this starting on petrol crap lol.. (he wont travel so i cant get him to look at it)
    Vp series 2
    Jun 2008
    you could try getting a very large syringe and filling it with petrol then pushing it into the fuel line( undo filter then start it and swap to gas straight up.
    mine has a button under the control box to manualy change it over to gas. you could TRY holding that while cranking. Gas will not flow at start up if
    A. throttle open more then 5%
    b. engine speed below 300rpm
    these are both safetl procedures to stop backfires.
    If you have a mate in to old style performance cars maybe you can borrow his holley blue pump to start your car.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Belt the tank with your fist or a rubber mellet and try and shock your pump back into life.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    going to go pick it up now, ill give all them a shot thanks boys appreciate the help...
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    hey mate.
    so you dont have a switch at all?
    if you do have a switch.. put it onto petrol turn the reds on then change it to gas and crank it till it starts..
    this is the method my lpg install told me to take if i run out of petrol and wanted to start the car on gas.
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Try bashing the tank with a RUBBER mallet as Haydz said. Or get a jerry can and pour a couple of litres into the tank, this prime the pump making you able to start the car.
    Both methods i used when my fuel pump died. best of luck
    Jul 2008
    I forgot to mention mine also has a switch, But it still does give it a squirt of fuel when you are starting on gas, usualy floods it and makes starting a bitch unless you crank it before the fuel pump fully primes.
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    Nah, i have a switch haydz, 1 side uses ONLY petrol, the other side of the switch HAS TO start on petrol then flicks over to gas when you rev it.... i also tried what you said about the switch and it didn't work.....
    Anyways the car is in my driveway right now, and waiting for a new fuel pump to come..
    fuel pump is completely dead, the rubber mallet trick didnt work.....
    also i used aerostart down the throttle body like davovp said and it worked a charm, gave me the couple seconds i needed for it to switch over...... thanks heaps guys, appreciate the help....
    YAY!!! now to take the car to the gas guy and get him to change my switch
    Vp series 2
    Jun 2008
    is it a gas optics unit?
    mine has a override switch under the black box.
    Tiny thing and hard to find if you don't know its there.
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    good question mate, i dont know what brand it is.... ill have a little look tomorrow and see.....
    i replaced the fuel pump early today aswell, so no more of this crap anymore (until this pump dies lol)
  1. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  2. VP 5litre running bad, dead fuel pump?
    By tysons_2001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2007, 08:48 AM
  3. Fuel pump dead????
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-03-2007, 12:55 PM
  4. VR V6 Exec - Fuel Warning Light Dead
    By NKX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2007, 09:16 PM
  5. Dead fuel and temp gauges
    By -VnExEc- in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2006, 01:20 PM
