Results 1 to 6 of 6
Thread: VN cutting out while driving
    Feb 2008
    Default VN cutting out while driving
    Hey guys, my 89 VN S-pac cuts out while driving.
    In more detail, while you are driving, it will cut out, it feels like someone pulls a plug out, then puts it back in. So while im driving it cuts out for a second or two, then kicks back in, then cuts out, then back in, it does it for a while, and eventually ill have to pull over. its sometimes worse and sometimes, not so bad.
    im so sure theres something wrong with the ignitions, because theres no spark. ive been told it is the crank angle sensor, but it mainly does it a few minutes after start up, sometimes it will do it 30mins after start up.
    i pulled the plug out of the crank angle sensor and put it bak in, it doesnt do it as much, but still does. anyone hav the same problem before?
    thanks in advance!! see ya!!
    Ossama Bin Laden >>>>>>>>>>> Hide n' Seek Champ since 2001
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    DFI unit, coils or CAS
    and 3 Dangerous non ABS VN's
    Feb 2008
    anyone know anything?
    88GreenVN's Avatar
    Jun 2006
    First thing to check is the coils - that would be my first choice going on what every other VN/VP/VR/VS driver has done when displaying the same symptoms as you've discribed. Can be CAS - but that happens when the car gets hot and is more like no go untill cooled down.
    Can be ECU or a wire making bad contact.
    But I'd start with the coils. - see if you can swap it with a known good unit.
    89 VN Exec, 94 VR SS
    Dec 2007
    If its a V6 its probably the coil pack, mine used to do what you said, coil would cut out from random reasons mainly just engine vibration and the car would stall, this will also ruin your starter motor from constant restarting it too
    Feb 2008
    thanks guys, ill change the coil pack.
    i recon im going to sell the car soon, so if anyone is interested lol, keep an eye out on the 'for sale' section. vn s-pac 5 speed manual with full calais options...
  1. amp cutting out
    By tyrefryer in forum Car Audio
    Last Post: 09-08-2008, 04:24 AM
  2. more air for pod..cutting ?
    By beefcream in forum V6 Development And Modification
    Last Post: 11-12-2007, 11:08 PM
  3. VR ss cutting out
    By SERGE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2007, 12:12 PM
  4. Amp keeps cutting out?? PLS HELP
    By Holdenboy_VS in forum Car Audio
    Last Post: 17-01-2007, 10:57 PM
  5. Amp cutting out!!
    By donz in forum Car Audio
    Last Post: 01-11-2006, 08:37 AM
